t-mag boi Posted June 21, 2008 Report Share Posted June 21, 2008 hello there, when i went to put a new set of pads on my bike i noticed that 1 of the holes u put one of the 4 bolts in was threaded and now my bolt is stuck. I would really appreiciate if someone can tell me how to get my bolt out. I am really desperate to get it out so the sooner the reply the better thanks michael riding t-mag Quote Link to comment Share on other sites More sharing options...
G-baby158 Posted June 21, 2008 Report Share Posted June 21, 2008 Have you tried getting it out with a allen key ? If it wont come out you might have to get a drill to it. Quote Link to comment Share on other sites More sharing options...
eskimo Posted June 21, 2008 Report Share Posted June 21, 2008 The most common way would be to drill it, tap it, helicoil it. Search on them ways and it'll be better than new. Quote Link to comment Share on other sites More sharing options...
higgzGU! Posted June 21, 2008 Report Share Posted June 21, 2008 Alright michael, Well the way i done it on my czar was, i filed down the bolt and centre punch it then get a drill and a 3mm drill peice and drill right down into the bolt after that i used an easy out but didn't work the first time so sprayed it with wd-40 for 5-10 minutes and tryed again and it worked. But if you drill down the bolt and the bolt splits in two then it should just fall out. hope this helps you michael Craig Quote Link to comment Share on other sites More sharing options...
t-mag boi Posted June 26, 2008 Author Report Share Posted June 26, 2008 yo cheerz guys thanks for the help MICHAEL RIDING T-MAG Quote Link to comment Share on other sites More sharing options...
mintsauce96 Posted June 27, 2008 Report Share Posted June 27, 2008 hello there, when i went to put a new set of pads on my bike michael riding t-mag Might be easier to take your wheel out to do this next time??? Defo less risky for dodgy 4bolt threads Quote Link to comment Share on other sites More sharing options...
