Dob Magnesium
matt-echo team
mod with freewheel...
Best off ringing tarty and some bb,freewheel crank, bash set ups will rub. Ring them and tell them what crank bash and freewheel you have and they should be able to tell you what you can use.
heres mine if it helps
DOB 20" hs33 frame
Isis bb 68x118
Try-all cranks
Try-all freewhell 108
Try-all cnc rear hub and cog
chains is from halfords about 7mm wide is really close to rubbing of frame anthing wider wont fit unless i put more spaces on the freewheel
better going to a bike shop and try a few bb sizes to see whats fits best i had a few bb lying about the garage to try and make sure its a narrow bb body as its smaller in the centre of the hole of the bb
