smoke257 Posted June 20, 2008 Report Share Posted June 20, 2008 Hey, i had a quick search and couldent realy find much, but my try all freewheel keeps skiping every so often, and theres a creaking sound (might be my crank though). Just wondering if you think its proably dead or just in need of a good ol clean out. Its not very loud wich leads me to think theres allot of muck or grese in there. And i wanted to no if there easy to take apart and put togeather again, iv serviced a tensile before that was pritty easy but the bearings were in cages, is the same in the tryalls? and are they easy to put back togeather? Cheers Jon Quote Link to comment Share on other sites More sharing options...
Mark W Posted June 20, 2008 Report Share Posted June 20, 2008 I can't remember what the bearing assembly's like, but if it's like the Tensile ones then it should be relatively straight forward. If it's not, have fun* Just remember there's another few pawls in there, so yeah, that'll just be a bit more hassle but it'll be fundamentally the same thing. As for the creaking, I'd imagine that'd be either BB or crank related. Just strip it all down, grease everywhere where there's metal-to-metal contact, and you should be able to eliminate the noise *You can put some grease on the inside of the bearing seats, to 'stick' the bearings into the freewheel. When it's reassembled, flush it through with GT-85/WD-40/whatever a few times to get rid of the grease. Quote Link to comment Share on other sites More sharing options...
CurtisRider Posted June 20, 2008 Report Share Posted June 20, 2008 mega noobz question that is relevant here i guess: my tryall skips like f**k, its new so im guessing its bedding in? is that normal for them? should i do the the good old wd40 flush to get rid of the crappy grease? Quote Link to comment Share on other sites More sharing options...
Mark W Posted June 21, 2008 Report Share Posted June 21, 2008 I would, yeah, but freewheels don't really require much bedding in, in that they're simple as f**k, open-bearing, WYSIWYG components. And Try-Alls are dick. Quote Link to comment Share on other sites More sharing options...
Echo-Scott Posted June 21, 2008 Report Share Posted June 21, 2008 I would, yeah, but freewheels don't really require much bedding in, in that they're simple as f**k, open-bearing, WYSIWYG components. Just out of curiousity, what is acctully happening when a freewheel is bedding it? Is it just the pawls wearing down abit to sit flush with the teeth or just the freewheel pushing all the grease out of the way or what? :S Quote Link to comment Share on other sites More sharing options...
Mark W Posted June 21, 2008 Report Share Posted June 21, 2008 Mixture of both, to some extent. Also, bearings need to get seated into the races properly 'n' stuff. Quote Link to comment Share on other sites More sharing options...
CurtisRider Posted June 21, 2008 Report Share Posted June 21, 2008 I would, yeah, but freewheels don't really require much bedding in, in that they're simple as f**k, open-bearing, WYSIWYG components. And Try-Alls are dick. thats what i figured, i shall give it a spray cos it really isn't very confidence inspiring! why do you think they are so bad? it seems well built from what ive seen so far Quote Link to comment Share on other sites More sharing options...
CurtisRider Posted June 21, 2008 Report Share Posted June 21, 2008 well i oiled it....no troubles so far:) clicks a beauty! Quote Link to comment Share on other sites More sharing options...
