Magura Hs33s
bikeperson45
just let the tyre down to get the wheel out ,you could run the same bleed for years duck so no worrys, also id rate them really well , but ther is better vee set ups , over all ther mint with the right pads!!
Edited by padarik
As above really :)
Take time to learn to set them up, get a good working rim/pad combination and you will have an awesome brake. They need alittle maintenance and fiddling to keep them on top form though, occasionally you may need to reset them as the pads wear - I dont use the TPA at all as it just makes one pad move earlier (still never worked out why this happens :unsure: ) so just reset the pads. 4 bolts mounts are stiffer and easier to set up, if you have canti bosses then youre probably better getting a decent V brake.
The only times I bleed my magura is if I split a hose or need to split the hosing.
If your tyre is soft enough then you can usually squash it with your fingers and squeeze it between the pads, if not just let it down :)
