sstein Posted June 18, 2008 Report Share Posted June 18, 2008 (edited) Does any one know how to stop the problem of the tension slowly changing when using chain tugs? It is really starting to piss me off having to stop every half hour, especially seeing as one side moves slightly quicker causing the brake to rub before the chain goes slack. Please don't suggest snail cams as I have no intention of modifying my frame. Also does anyone know where I can find threshold tugs as they look very good Edited June 18, 2008 by sstein Quote Link to comment Share on other sites More sharing options...
Concussion Posted June 18, 2008 Report Share Posted June 18, 2008 What ones are you using? Quote Link to comment Share on other sites More sharing options...
Nickkkkk Posted June 19, 2008 Report Share Posted June 19, 2008 i no its not what your after but will save you a whole world of trouble by investing in some "snail cams". i used to run tugs and mine did exactly what yours are doing, they keep altering and make your pads rubs even when you think you have set them up perfectly. take it to you local engineering firm lol and tell them what you are wanting. SNAIL CAMS ALL THE WAY!!! Nick Quote Link to comment Share on other sites More sharing options...
MattB Posted June 19, 2008 Report Share Posted June 19, 2008 With snail cams you shoudn't have to modify your frame. On most frames there will be 2 littles hole on the inside near the drop out where the bolts go in. If not then you could either drill or get new chain tugs as I know people who have been fine with them. Matt Quote Link to comment Share on other sites More sharing options...
