jordon23 Posted June 17, 2008 Report Share Posted June 17, 2008 hi is the monty brake spray good or not .also where can i get tar from? thx jordon Quote Link to comment Share on other sites More sharing options...
txt2007 Posted June 17, 2008 Report Share Posted June 17, 2008 hi is the monty brake spray good or not .also where can i get tar from? thx jordon helps if you put the text accually inside the code and most people rob it off roads heat it up and remove the rocks but if you really cant be bothered some people might have some spare that they might be able to sell you, i'm not sure about the brake spray take it's for disks? b'cuz i'd just use cheaper stuff, paying for the brand name and all that. Quote Link to comment Share on other sites More sharing options...
jordon23 Posted June 17, 2008 Author Report Share Posted June 17, 2008 helps if you put the text accually inside the code and most people rob it off roads heat it up and remove the rocks but if you really cant be bothered some people might have some spare that they might be able to sell you, i'm not sure about the brake spray take it's for disks? b'cuz i'd just use cheaper stuff, paying for the brand name and all that. disk front and a hs33 back Quote Link to comment Share on other sites More sharing options...
BenLeacock™ Posted June 17, 2008 Report Share Posted June 17, 2008 Give up ! What brakes do you run Front disk rear magura ? Well im pritty sure that the disk spray isnt for magura ! Quote Link to comment Share on other sites More sharing options...
Callum-Luvs-Trials Posted June 17, 2008 Report Share Posted June 17, 2008 (edited) Well im pritty sure that the disk spray isnt for magura ! Ow crap Edited June 17, 2008 by Callum-Luvs-Trials Quote Link to comment Share on other sites More sharing options...
BenLeacock™ Posted June 17, 2008 Report Share Posted June 17, 2008 (edited) Ow crap After reading i was wrong, it is for magura - Great little brake-improving invention from the original BikeTrials brand Monty! - We've nicknamed this stuff 'Tar in a Can', and it's really useful to improve your brake instantly! - Brake spray is extremely easy to apply and works great in all conditions. - The main thing to bear in mind is that you only need a light coating - too much will make your brake worse! - Simply dry/clean your rim off with a clean tissue or cloth, lift the wheel off the ground and spin it. While its spinning, spray a light coating on the braking surface, and then scrub it round with your brake pads. Wait a few minutes for it to dry and you're away! - Sold in an easy-to-use single aerosol can. Edited June 17, 2008 by BenLeacock™ Quote Link to comment Share on other sites More sharing options...
Callum-Luvs-Trials Posted June 17, 2008 Report Share Posted June 17, 2008 After reading i was wrong, it is for magura When you buy brake pads through, it says "The use of tar or brake spray my reduce wearlife on the pads." So I dont know if it actually does any good. I have heard that it ruins your rim and just turns really sticking and makes your brake Shit after some time. Which results in constantly cleaning your rim and pads. Big No No Quote Link to comment Share on other sites More sharing options...
jordon23 Posted June 18, 2008 Author Report Share Posted June 18, 2008 iv got disk front hs33 back or where can i get tar? thanks Quote Link to comment Share on other sites More sharing options...
txt2007 Posted June 18, 2008 Report Share Posted June 18, 2008 helps if you put the text accually inside the code and most people rob it off roads heat it up and remove the rocks but if you really cant be bothered some people might have some spare that they might be able to sell you, i'm not sure about the brake spray take it's for disks? b'cuz i'd just use cheaper stuff, paying for the brand name and all that. there was some on ebay a while ago, buit of a rip off if you ask me, why do you want to put sticky stuff all over your rims any way? just get a grind it'd probably be easy cheaper and wont wreck the look of a bike. Quote Link to comment Share on other sites More sharing options...
Chandler Posted June 18, 2008 Report Share Posted June 18, 2008 Monty brake spray is awsome.... problem is it wears off after 1 ride/a couple of hours Its better than tar cos it actually cleans ur pads instead of gunking them up It also feels better (less squishy than tar is the only way to describe) The problem is its too expensive to use regularly (Dont ask me how many sprays you get from each can though lol) I say grind your rims lightly, use tar lightly sometimes, and monty brake spray for special occasions! Quote Link to comment Share on other sites More sharing options...
Rebelistic Posted June 18, 2008 Report Share Posted June 18, 2008 I've got some brake spray, It's pretty good. If your brake performance is a bit poor then it is a good 'quick fix'. I've not put any on since re-grinding my rim though, there seeems to be no need. As for cost, it seems expensive but 1 can lasts for ages as you only apply a tiny bit. Quote Link to comment Share on other sites More sharing options...
Crazyman Posted June 18, 2008 Report Share Posted June 18, 2008 Monty spray is much better than tar(in my experience).Tar has a lot of "-", one of them if you salve a lot of tag on rims, pads can adhere to rim. Spray also has a "-":he is ends fast, if you ride a lot of time every day(( and I heared that some type of pads bad matched with spray... try to use grind with hard pads...i think that you love it combination)) good luck! Quote Link to comment Share on other sites More sharing options...
