Rim/spoke Patterns
monty221pr
After riding bmx for a few weeks i have noticed on alot of good bmx wheels the spokes are slightly off set on the rim surely this is stronger as it wud be harder to crush the wheel? (Less flat spots :D)
Any good reasons why this has not been used for trials wheels? or is it new or something?
Sam.
Edited by monty221pr
far as i know...most rims have the spoke holes slightly offset for that very reason...
think i've seen a "concept" trial rim on here before with a very distinct offset like you said...anyone else remember? might've been bmx..
they're probably more expensive to make!
Bontrager made some MTB rims with the spoke holes offset to reduce dish back in the 90's. All the spoke holes were to the same side of the rim so the angle between the spokes fro each side of the hub and the plane of the wheel was closer to equal (So the rim was as strong laterally in loading from either side).
Most rims have every second spoke offset slightly off the rim's centreline to reduce binding between the spoke nipples and the rim (You lace spokes from the LH flange to the spoke holes offset to the left). To make wheels stronger in side loading a rim with no spoke hole offset will be better because the spokes make a bigger angle relative to the plane of the wheel.
There is a wheel building technique known as crossover lacing where the spoke angle is increased by lacing from the LH hub flange to the RH offset spoke holes. This only works in some rim/hub combinations without the spoke nipples binding in the spoke holes (Hubs with the flanges quite close together are best for this - these will be most prone to building wheels that are weak in side loading too, so worth trying if you want a particular hub rim combination but keep turning it into a pringle on sideways landings.
dont forget though, no rim EVER has the spoke holes directly down the middle... how else would you true out a buckle?
Interesting to read this though, I had no idea how much the DOB rims were offset
You can true out buckles because half the spokes pull to each side of the hub. This means a triangle is formed with two spokes for two sides and the space between the hub flanges is the third side. If the spoke holes are offset the triangle sides formed by the spokes don't meet at a point but the principle is the same. Turning the spoke nipple effectively lengthens or shortens the spoke, moving the rim from one side to another. Spoke offset does not affect how easy a wheel is to true (Unless the spoke nipple binds in the hole in the rim because the hole is offset too much).
Edited by psycholist
