Is There Any Way To Repair The Threds On A Crank.
mista-neos
If the pedals were cross threaded then you can tap it out again pretty easily.
If their really messed then you can helicoil it. Im pretty sure they come in that size and once you have then the threads will be far stronger then they were before.
I still cant believe that deng cranks dont come with and insert. Its madness!!
