ginger allen echo Posted June 15, 2008 Report Share Posted June 15, 2008 (edited) hey, ive got sum black gu flat bars and im wanting to change them to silver. can i just sand them down and that will be it? ginger allen Edited June 15, 2008 by ginger allen echo Quote Link to comment Share on other sites More sharing options...
Oli Smith Posted June 15, 2008 Report Share Posted June 15, 2008 yes. Quote Link to comment Share on other sites More sharing options...
RossMcd Posted June 15, 2008 Report Share Posted June 15, 2008 yes. +1 make sure u laceur (sp?) them though or use a very fine sand paper or they wont look to great. Quote Link to comment Share on other sites More sharing options...
ginger allen echo Posted June 15, 2008 Author Report Share Posted June 15, 2008 +1 make sure u laceur (sp?) them though or use a very fine sand paper or they wont look to great. how would you use the laceur? its my first time doing this Quote Link to comment Share on other sites More sharing options...
Ben John-Hynes Posted June 15, 2008 Report Share Posted June 15, 2008 Are they not anodised? If so, you'll need to buy some Mr. Muscle oven cleaner(contains caustic soda) which will strip the colour off the bars, but after this is done you will need to sand them down because the caustic soda leaves a horrible finish. Quote Link to comment Share on other sites More sharing options...
ginger allen echo Posted June 15, 2008 Author Report Share Posted June 15, 2008 Are they not anodised? If so, you'll need to buy some Mr. Muscle oven cleaner(contains caustic soda) which will strip the colour off the bars, but after this is done you will need to sand them down because the caustic soda leaves a horrible finish. i think there anodised with a gloss finish Quote Link to comment Share on other sites More sharing options...
Ben John-Hynes Posted June 15, 2008 Report Share Posted June 15, 2008 So you'll need to put the bars somewhere(possibly a bath) and spray the mr. muscle over them, Leave them for about 30mins and check on them, if all of the colour has come off, wash and sand them, If the colour is still there, put more mr. muscle on them and check every 5-10 mins. Quote Link to comment Share on other sites More sharing options...
adam 94 Posted June 16, 2008 Report Share Posted June 16, 2008 Yes just sand them down and they will turn silver because someone I know called bazz done it. Quote Link to comment Share on other sites More sharing options...
Diz Posted June 17, 2008 Report Share Posted June 17, 2008 (edited) Rather than sand them down and risk having a really crappy finish on them, buy yourself some nitro-mors. This stuff is hardcore, i used it to strip the paint off my frame. All you do is paint it onto the bars, leave for a bit. Touch it up a bit with some more, then the paint will just wipe off. Just a note though, wear thick gloves to do this. The latex ones i used dissintegrated and so did some of the skin on my fingers...like i said...its hardcore stuff! Available from most diy stores, B&Q etc. Also, to lacquer the bars, use a spray lacquer (also available from B&Q etc) and apply several thin coats. Be patient with it all though, the longer you take, generally the better the finish. Edited June 17, 2008 by Diz Quote Link to comment Share on other sites More sharing options...
basher Posted June 18, 2008 Report Share Posted June 18, 2008 Rather than sand them down and risk having a really crappy finish on them, buy yourself some nitro-mors. This stuff is hardcore, i used it to strip the paint off my frame. All you do is paint it onto the bars, leave for a bit. Touch it up a bit with some more, then the paint will just wipe off. Just a note though, wear thick gloves to do this. The latex ones i used dissintegrated and so did some of the skin on my fingers...like i said...its hardcore stuff! Available from most diy stores, B&Q etc. Also, to lacquer the bars, use a spray lacquer (also available from B&Q etc) and apply several thin coats. Be patient with it all though, the longer you take, generally the better the finish. Nitromorse won't strip anodising off its not strong enough. Quote Link to comment Share on other sites More sharing options...
kristaps Posted June 18, 2008 Report Share Posted June 18, 2008 ...after sands finish your handlebar with Alu Magic-that will protect aluminium from water Quote Link to comment Share on other sites More sharing options...
Ben John-Hynes Posted June 18, 2008 Report Share Posted June 18, 2008 ...after sands finish your handlebar with Alu Magic-that will protect aluminium from water Hahaha Quote Link to comment Share on other sites More sharing options...
Danny Swindlehurst Posted June 26, 2008 Report Share Posted June 26, 2008 costic soda ->crome polish -> laque... thats all you need love Quote Link to comment Share on other sites More sharing options...
davey90 Posted June 29, 2008 Report Share Posted June 29, 2008 (edited) Another cheap option is to rub the bars down with Silvo, its the equivalent to Brasso and can be bought in Tesco for about £1.80, i used it to polish up a set of anodised Shimano cranks as it removes the anodising although it is a slow process the finish is really good Edited June 29, 2008 by davey90 Quote Link to comment Share on other sites More sharing options...
