How Do I Merge Images On Cs2?
Davetrials
How do people merge the images together for one of those photos where theve taken a few pictures of them self and banged it all in one photo?
Ctrl+N, Ctrl+C, Ctrl+V then move shape and blend with eraser, overlays and effect.....
Open all the images
Drag all the images onto image you've set as the base
Using layer masks, erase all the areas you dont want on each layer, leaving the base layer left alone
sorry for nicking your thread mate, but if anyone knows, how do you leave some parts in colour and the rest in black and white? I use to remember but i've forgotten :(
I've tried searching too :)
JK
Using the above techniques in a similar fashion, you can do it by...
Opening image
Duplicate base layer
Apply a saturation adjustment layer to the base layer, desaturating it completely
Make sure the adjustment layer is between the two layers too, or it will desaturate both layers
Using a mask on the top layer, erase all sections you dont want.
EDIT: Sorry if that's a bit complicated for you guys, that's the way I do it as it's completely non destructive, meaning you can always erase the masks or the adjustment layer to go back to the original document.
Edited by Mark King
