Grips
Sam Jones
Yea sam either cut em off, or get a thinish screwdriver, shove it as far under the grip as you can get it, and squirt water/lube/hairspray under there, pull screwdriver out, and twist.
If the grip is stiff enough (Not one of the really thin sticky rubber grips) you can use the brake lever to push it off - just loosen the lever clamp and slide it against the grip, this will bulge the end of the grip and unstick it enough to allow it to slide off. This works best with thick grips.
Use petrol to put the grips on and you have no problems getting them off :)
My odi roughnecks are worn super thin now and I can just roll them off the bars, a splash of petrol inside, slide them on and let them dry for 5-10 mins before riding and its all good.
i just get a thinish tea-spoon and push it down the tube. lift the spoon away from the handlebars and then spit into the gap you have made, even really stiff one should take just two spits ^_^lol. twist the grip when you have spit. p.s some people give some shocking advice :mellow:
Nick
Don't use petrol, it 'melts' grips.
Thats why Ive used it without a problem for the last 10 years with all my grips (motorbikes/jump bike/trials bike/bmx) :rolleyes:
Go on try it, watch your grips melt into a steaming piece of molten rubber :-
stop being stupid! using petrol will make your grips stink for ages and feel weird, just spit on the buggers :S why go to such extremes when the simple stuff works well when done properly
Nick
Edited by Nickkkkk
Nick
My phlegm isnt sticky enough :D
I have petrol readily available from the motorbike in my kitchen ;)
Nick
well no it wont make your grips stink because you put it on the inside of them, you only use a little bit and if you buy new grips they wont smell and even if you dont buy new ones the petrol will have evaporated and once again not smell. and what on earth would make them 'feel weird'???
lol have you ever bled your brakes and got oil all over your grips? (rhetorical question) If so you will know they feel spongy and slippy for days after, can't be bothered arguing all i know is petrol isn't needed for removing grips xxx
Nick
I got them off the way skoze had said. It was brilliant. Seriously easy. I did modify the method a bit. I used boiling water a screw driver and the brake lever. Soaked the grip whilst the screw driver was stuck between the grip and handlebars. then i used the brake lever to pull it off. cheers for the help.
