Ben H! Posted June 9, 2008 Report Share Posted June 9, 2008 hi people i today when i was out on my bike i noticed that the rear wheel kept wobbling to the left hand side and it wouldn't stay straight is this normal? does anyone know what is causing this cheers Ben Quote Link to comment Share on other sites More sharing options...
Ben John-Hynes Posted June 9, 2008 Report Share Posted June 9, 2008 it wouldn't stay straight is this normal? Obviously it's not normal! The cones may be loose, the axel bolts may not be tightened properly, spokes may be loose. Quote Link to comment Share on other sites More sharing options...
Ben H! Posted June 9, 2008 Author Report Share Posted June 9, 2008 Obviously it's not normal! The cones may be loose, the axel bolts may not be tightened properly, spokes may be loose. i don't know why i put ''is this normal'' axle bolts are both very tight not to sure on the spokes though Quote Link to comment Share on other sites More sharing options...
Ben John-Hynes Posted June 9, 2008 Report Share Posted June 9, 2008 Lol Just give the spokes a quick go over then, Just don't tighten them too much. Quote Link to comment Share on other sites More sharing options...
Ben H! Posted June 9, 2008 Author Report Share Posted June 9, 2008 Lol Just give the spokes a quick go over then, Just don't tighten them too much. ok then it's just my gay bike it's always broken Quote Link to comment Share on other sites More sharing options...
jay2008 Posted June 9, 2008 Report Share Posted June 9, 2008 My full sus did that so i took the cones and axle out to check and found the axle had somehow snapped/sheared straight in half! Might be worth a look Quote Link to comment Share on other sites More sharing options...
Ben H! Posted June 9, 2008 Author Report Share Posted June 9, 2008 My full sus did that so i took the cones and axle out to check and found the axle had somehow snapped/sheared straight in half! Might be worth a look cheers nice on mate i'll get my dad to have a look at it on saturday cheers mate Quote Link to comment Share on other sites More sharing options...
jay2008 Posted June 9, 2008 Report Share Posted June 9, 2008 No problem, it was quite a smooth break, very clean. Still no idea to this day how I managed it! It was a quick release axle so could have been that. When you check it, have a close look around the cones too as it is a fine shear and if it is broken, it could be right near to the thread. Hope you get it sorted matey Quote Link to comment Share on other sites More sharing options...
Ben H! Posted June 10, 2008 Author Report Share Posted June 10, 2008 No problem, it was quite a smooth break, very clean. Still no idea to this day how I managed it! It was a quick release axle so could have been that. When you check it, have a close look around the cones too as it is a fine shear and if it is broken, it could be right near to the thread. Hope you get it sorted matey it also feels very hard to pull up on the front wheel which is so annoying Quote Link to comment Share on other sites More sharing options...
otaylor38 Posted June 10, 2008 Report Share Posted June 10, 2008 uhave you tried to tighten the bearings? these are two things at each side of the wheel just tighten them with a spanner. Quote Link to comment Share on other sites More sharing options...
craigjames Posted June 10, 2008 Report Share Posted June 10, 2008 if its running really rough and theres lots of drag, then i imagine you've snapped the axle like has been said or the bearings are crushed; creating slack and movement but also stopping them from running smoothly. Quote Link to comment Share on other sites More sharing options...
Ben H! Posted June 11, 2008 Author Report Share Posted June 11, 2008 if its running really rough and theres lots of drag, then i imagine you've snapped the axle like has been said or the bearings are crushed; creating slack and movement but also stopping them from running smoothly. cheers mate i'll get it sorted soon Quote Link to comment Share on other sites More sharing options...
Ben H! Posted June 16, 2008 Author Report Share Posted June 16, 2008 (edited) found that the rim is slightly buckled at one side i'll get it fixed this week Edited June 16, 2008 by Czartrials Quote Link to comment Share on other sites More sharing options...
keeps21 Posted June 17, 2008 Report Share Posted June 17, 2008 found that the rim is slightly buckled at one side i'll get it fixed this week I've found that truing buckled wheels isn't too difficult, and is definitely a good skill to have. Have a read through the repair/how tos here: http://www.parktool.com/repair/ Quote Link to comment Share on other sites More sharing options...
Gogz- Posted June 17, 2008 Report Share Posted June 17, 2008 (edited) ok then it's just my gay bike it's always broken you need to get used to your bike being broken and having to fix it when your riding trials.... Edited June 17, 2008 by gogz69 Quote Link to comment Share on other sites More sharing options...
Diz Posted June 17, 2008 Report Share Posted June 17, 2008 you need to get used to your bike being broken and having to fix it when your riding trials.... Too true..annoyingly! Just a thought as well. I was riding one of my bikes and it kept doing the same thing, going off to one side. It wasnt till ages later i realised i'd actually snapped the frame on the chainstays. Hopefully its not the case for you, but worth checking just in case. Quote Link to comment Share on other sites More sharing options...
sstein Posted June 17, 2008 Report Share Posted June 17, 2008 Had a problem like this. I trued the wheel and it was still doing it, it was only then I realised I had snapped the axle in the middle and it was being held together by the quick release skewer. Quote Link to comment Share on other sites More sharing options...
