czarbikes Posted June 8, 2008 Report Share Posted June 8, 2008 can you help me cutting out the front of my head tube please cheers jamie Quote Link to comment Share on other sites More sharing options...
Luke Rainbird Posted June 8, 2008 Report Share Posted June 8, 2008 Ok, pass it here? Quote Link to comment Share on other sites More sharing options...
Ash-Kennard Posted June 8, 2008 Report Share Posted June 8, 2008 LOL luke Quote Link to comment Share on other sites More sharing options...
Ryan!1991 Posted June 8, 2008 Report Share Posted June 8, 2008 (edited) What to do is drill a hole near the top and bottom of the head tube then drill two in the middle but at the sides but keeping it on the face of the head tube so your not weakening it. Then take a blade out of a hack saw put it in a hole cut it out like dot to dot then if you have a file take it and neaten it up. Then with a fine sand paper take the rough edges off after this you should end up with a dimond shape in your top tube. This will save waight and looks pritty nifty hope iv helped regards Ryan Edited June 8, 2008 by Ryan!1991 Quote Link to comment Share on other sites More sharing options...
czarbikes Posted June 8, 2008 Author Report Share Posted June 8, 2008 What to do is drill a hole near the top and bottom of the head tube then drill two in the middle but at the sides but keeping it on the face of the head tube so your not weakening it. Then take a blade out of a hack saw put it in a hole cut it out like dot to dot then if you have a file take it and neaten it up. Then with a fine sand paper take the rough edges off after this you should end up with a dimond shape in your top tube. This will save waight and looks pritty nifty hope iv helped regards Ryan cheers that has helped me loads Quote Link to comment Share on other sites More sharing options...
Ryan!1991 Posted June 8, 2008 Report Share Posted June 8, 2008 cheers that has helped me loads glad i could help Quote Link to comment Share on other sites More sharing options...
