sstein Posted June 6, 2008 Report Share Posted June 6, 2008 I just bought a 24/7 trials frame off ebay and i am using it with a 46mm echo rim. The problem that I have is that I have previously used truvativ ruktion cranks, however the spacing on this frame is odd and the chainring is almost too close to the chainstay and the end of the crank almost touches the brake, so I have trouble positioning the brake so that it doesn't rub. Does any one else have this problem and if so what cheap isis cranks would you reccomend getting. I don't mind squares I just don't mind square taper, just don't want to spend money on something that is very easily rounded. Quote Link to comment Share on other sites More sharing options...
Alex Dark Posted June 6, 2008 Report Share Posted June 6, 2008 okay...best isis cranks are probably echo cnc cranks ... about £65 at the moment and seriously awesome cranks Sq. taper are a bit rare now adays but maybe some ddg orbita's or the like.... Quote Link to comment Share on other sites More sharing options...
psycholist Posted June 6, 2008 Report Share Posted June 6, 2008 Fit a longer BB axle. Problem solved... Quote Link to comment Share on other sites More sharing options...
MikeCottTrials Posted June 6, 2008 Report Share Posted June 6, 2008 Fit a longer BB axle. Problem solved... get yourself a 128/127.5mm width bb and you'll be sorted Quote Link to comment Share on other sites More sharing options...
