jay2008 Posted June 4, 2008 Report Share Posted June 4, 2008 On my onza t-bird I have an alex rim, don't know any more than that. When i ride normally, it makes a strange sound, sort of a metal clicking/twanging sound. That probably doesn't make much sense but its hard to describe! I know the wheel is slightly buckled and I'll be getting a new one but can anyone give me pointers to sort it just in the mean time? Is there a chance the spokes need tightening? If yes, how do I do that properly? Much grateful! Quote Link to comment Share on other sites More sharing options...
Karl Butcher Posted June 4, 2008 Report Share Posted June 4, 2008 (edited) Hmm it could be you need a new alex thats what happend to mine when i had one! but you said twanging so its more likely to be your spokes my mates spokes make that sound all the time!!! if you go on Wiki you might find somthing on there to help you Edited June 4, 2008 by Karl Butcher Quote Link to comment Share on other sites More sharing options...
Anton Posted June 4, 2008 Report Share Posted June 4, 2008 ive had something similar... i found one of the spokes has snapped but it had kinda stayed in place and every now and then it would catch on something and spring back make some horrible noises sounds stupid but it happens Quote Link to comment Share on other sites More sharing options...
charlie >est< Posted June 4, 2008 Report Share Posted June 4, 2008 I get a similar thing on my Echo hub. When my chain is too tight it will clunk. Try that?? Quote Link to comment Share on other sites More sharing options...
jay2008 Posted June 4, 2008 Author Report Share Posted June 4, 2008 Thanks for the replies guys, I'll try the chain thing, what is the best tension to have a chain? I do know the spokes are slightly loose, some more than others.jay Quote Link to comment Share on other sites More sharing options...
Skoze Posted June 4, 2008 Report Share Posted June 4, 2008 Thanks for the replies guys, I'll try the chain thing, what is the best tension to have a chain? I do know the spokes are slightly loose, some more than others.jay so that you can push it down a little, but so that it looks fairly tight, and doesn't dropp dramatically towards the chainstay Quote Link to comment Share on other sites More sharing options...
jay2008 Posted June 4, 2008 Author Report Share Posted June 4, 2008 Thanks for all replies, I think i'll just put up for it for another month then getta new wheel when payday hits again! I will have a go with the chain tension and just fiddle really! Thanks again people Quote Link to comment Share on other sites More sharing options...
charlie >est< Posted June 4, 2008 Report Share Posted June 4, 2008 Thanks for the replies guys, I'll try the chain thing, what is the best tension to have a chain? I do know the spokes are slightly loose, some more than others.jay They shouldn't be making noise with a 'slight' movement. Is it the factory build? Quote Link to comment Share on other sites More sharing options...
jay2008 Posted June 4, 2008 Author Report Share Posted June 4, 2008 I think so, it was on the bike when my mate gave it to me. Unfortunately, he decided to leave it to rot in his garden for the best part of a year! so i'l slowly sorting it out Quote Link to comment Share on other sites More sharing options...
Mark W Posted June 4, 2008 Report Share Posted June 4, 2008 If you squeeze a pair of spokes together just above where they cross, if they're loose-ish feeling, it'll be your spokes moving when the pressure is on them. Either buy a spoke key and tighten them about half a turn each, or take it to a bike shop Quote Link to comment Share on other sites More sharing options...
jay2008 Posted June 4, 2008 Author Report Share Posted June 4, 2008 Just done that, they do feel a bit loose, I do have spoke key, sorry for asking loads, so if i do one each half turn it may solve the problem? thanks for everyones advice and replies Quote Link to comment Share on other sites More sharing options...
Mark W Posted June 4, 2008 Report Share Posted June 4, 2008 Do a half turn, and if they still feel loose, do another half turn. Repeat until tight When you ride it afterwards, you'll probably hear a few pings at first as the spokes settle down again, but it should quieten your wheel down after that. Quote Link to comment Share on other sites More sharing options...
Simpson Posted June 5, 2008 Report Share Posted June 5, 2008 Metal of your metal caliper rubbing on the rim? Quote Link to comment Share on other sites More sharing options...
jay2008 Posted June 5, 2008 Author Report Share Posted June 5, 2008 Metal of your metal caliper rubbing on the rim? Not as far as I can see! Quote Link to comment Share on other sites More sharing options...
gzus11 Posted June 5, 2008 Report Share Posted June 5, 2008 I used to get a noise that sounds like you describe on my old bikes. The hubs had cup/cone bearings and they made this noise if dirt got into the race, one had slight corrosion with the same noises and the last time I had it the cup had cracked all around the bearing face. I imagine cartridge bearings would behave similarly with any comtamination/corrosion As far as my experience goes the contamination caused the balls to make the noise which transfered out the spokes, similar to the noise of broken spokes. Another remedy you could try would be to strip the bearings and give them a good clean, inspect for any cracks, corrosion or dirt and carefully reassemble. Quote Link to comment Share on other sites More sharing options...
jay2008 Posted June 5, 2008 Author Report Share Posted June 5, 2008 I think that sounds like a good idea, thanks mate! I'll do that and post results soon thanks to all for replies and advice, has been a help Quote Link to comment Share on other sites More sharing options...
Revolver Posted June 6, 2008 Report Share Posted June 6, 2008 Whenever my wheel has made a metal twanging noise, it has been a spoke. You ought to check all your spokes are tight, and if not, tighten them! Quote Link to comment Share on other sites More sharing options...
jay2008 Posted June 6, 2008 Author Report Share Posted June 6, 2008 thanks for everyone's replies, but I have caved and just bought a cheap-ish alex to keep me riding Quote Link to comment Share on other sites More sharing options...
