Crazyman Posted June 4, 2008 Report Share Posted June 4, 2008 Hi guys!!! I would like to buy a new rear fixed hub on my mod bike. What's the best?And why this... Thanks. Quote Link to comment Share on other sites More sharing options...
eskimo Posted June 4, 2008 Report Share Posted June 4, 2008 Echo 08 i'd say. More bearings this time and have easy changeable sprocket setup. They come with a choice of one sprocket and snail cams so for the money it's great. Quote Link to comment Share on other sites More sharing options...
Crazyman Posted June 4, 2008 Author Report Share Posted June 4, 2008 I also think that echo 08 is really nice hubs....And what about Try-All "H" 116 Hub and Monty Rear Disc Hub? Quote Link to comment Share on other sites More sharing options...
jono_misfits Posted June 4, 2008 Report Share Posted June 4, 2008 If you could afford it then you can never go wrong with a Chris King, otherwise i would recommend the Monty 219 or the VIZ. Quote Link to comment Share on other sites More sharing options...
N.Wood Posted June 4, 2008 Report Share Posted June 4, 2008 If you could afford it then you can never go wrong with a Chris King, otherwise i would recommend the Monty 219 or the VIZ. Well you could go wrong, considering they don't make a fixed rear hub. Go Echo '08 Quote Link to comment Share on other sites More sharing options...
spartan Posted June 4, 2008 Report Share Posted June 4, 2008 Yeah for the money the echos are the best for sure. I hear the profiles are nice but ive never used one. The surly rear hubs are great and cheap but im not sure if they come with a 116 spacing. Its pretty hard to f up a single speed hub though. echo *** here people!! Quote Link to comment Share on other sites More sharing options...
Crazyman Posted June 5, 2008 Author Report Share Posted June 5, 2008 Oh thanks to all for the advices!! Ok, I understand that the echo 08 is good rear hubs but what's about Try-All "H" 116 Hub and Monty Rear Disc Hub? Echo is better than this hubs? p.s:I wouldn't like to use freehubs because chris king isn't a my choice Quote Link to comment Share on other sites More sharing options...
Muel Posted June 5, 2008 Report Share Posted June 5, 2008 It has to be the Try-All H, failing that the Monty TI. Quote Link to comment Share on other sites More sharing options...
JB1 Posted June 5, 2008 Report Share Posted June 5, 2008 I'd go for the Echo 08, works perfectly, looks great and is cheaper than the Try-all H. Quote Link to comment Share on other sites More sharing options...
forteh Posted June 5, 2008 Report Share Posted June 5, 2008 I'd go for the Echo 08, works perfectly, looks great and is cheaper than the Try-all H. Also twice the weight, depends if youre a weight weenie really Quote Link to comment Share on other sites More sharing options...
Maximus Posted June 5, 2008 Report Share Posted June 5, 2008 The best for the price is a onza t-master, good, strong, smooth hubs cheap at £30 half the price of other seald hubs. (dont get them confused with the t-pro hub) - if price is no object then try-all 'H' is the hub of choise! Quote Link to comment Share on other sites More sharing options...
Crazyman Posted June 5, 2008 Author Report Share Posted June 5, 2008 Grand thanks to all for the advices!!! Well...there are two good rear fixed hubs-try all and Echo...What the best between them? I think it's echo 08 Quote Link to comment Share on other sites More sharing options...
SuperDeathMonkey Posted June 5, 2008 Report Share Posted June 5, 2008 I got a monty 221ti hub. damn smooth and pretty strong, had no problems with it. If your buying a rear fixed you may aswell just get the cheapest out of the better few. The monty hub is only 60 something pounds on trials-uk. I'd recommend it. Quote Link to comment Share on other sites More sharing options...
ogre Posted June 5, 2008 Report Share Posted June 5, 2008 The best for the price is a onza t-master, good, strong, smooth hubs cheap at £30 half the price of other seald hubs. (dont get them confused with the t-pro hub) - if price is no object then try-all 'H' is the hub of choise! absolutley shit for staying in place, and the bolts are wank. bearings and construction is spot on. echo hubs have giant-man-bolts which is something i look for in everything i wouldn't trust the lightweight hubs like monty and try-all/koxx 'cause when you save on weight you tend to loose out on strength. go for the echo, or czar hub 'cause it's identical and cheaper Quote Link to comment Share on other sites More sharing options...
JB1 Posted June 6, 2008 Report Share Posted June 6, 2008 Also twice the weight, depends if youre a weight weenie really Fair point! I don't tend to worry to much about it. I grew up riding old school triple clamp fork Monty's which were fairly lumpy compared to modern decent spec mods. Quote Link to comment Share on other sites More sharing options...
