Sasha W. Posted June 3, 2008 Report Share Posted June 3, 2008 I'd like to compare Neon stem with Echo HiFi....... Cause the price is the same,but about the strengh?????? Quote Link to comment Share on other sites More sharing options...
monkeyseemonkeydo Posted June 3, 2008 Report Share Posted June 3, 2008 Looks like they're pretty much identical to me... probably made in the same factory from the same material. Choose the one with the right geometry for you. I've only used the Echo and it did a grand job of holding my bars to my fork via a metal tube . Quote Link to comment Share on other sites More sharing options...
Sasha W. Posted June 4, 2008 Author Report Share Posted June 4, 2008 Echo geometry is better for me(186cm high&1085 wheel base) but there are no Echo stems in Ukraine yet,so i am very sad 'bout that...... Neon is made from 2014+T6 alu,and Echo is from 7075+T6 it seems........ Anyway thanks for your comment I'd better wait for Echo,because i think that 20 degrees will be not good for V!Z fork(it has 415mm lengh) as Echo.... So thats why i'm not sure about the stem Quote Link to comment Share on other sites More sharing options...
