Scott Norman Posted June 2, 2008 Report Share Posted June 2, 2008 Ok i have a front disk hub that just has pro max printed on it. Dose any one know what size spokes i need?? I know when i buy spokes of tarty you tell them what hum rim and hole you have. But the thing is i dont know what pro max hub it is. I will get photos of it up tomorow. If any one on here has on can you tell me what size spokes i would need. for it being laced on to a 20" rim. Its silver and wide flanged. Thats all i can say lol. Cheers Scott. Quote Link to comment Share on other sites More sharing options...
_Owen. Posted June 3, 2008 Report Share Posted June 3, 2008 You will need to know the rim aswell. As all 20" rims dont take the same sized spokes. Best bet would be to buy just the rim off Tarty, then take your hub and rim to your local bike shop, and say, i want this hub laced to this rim, get me my spoke measurements! If they know what theyre doing, itl take them about 5 mins to get the right measurement. Then either ask them for the spokes, or go back to Tarty! Owen Quote Link to comment Share on other sites More sharing options...
Scott Norman Posted June 3, 2008 Author Report Share Posted June 3, 2008 Here is a photo of the hub. Please some one help. Quote Link to comment Share on other sites More sharing options...
Shieldzy Posted June 19, 2008 Report Share Posted June 19, 2008 Like the other guy said, go to your local bike shop with the hub and rim and they should be able to tell tou the size and they could most likely fit it if you book it in Hope i helped Dan Quote Link to comment Share on other sites More sharing options...
Shieldzy Posted June 20, 2008 Report Share Posted June 20, 2008 Maybe you should consider buying a new hub with maybe a full wheel build even because promax are a pretty bad and cheap and weak make. Just a suggestion. Hope I helped Dan Quote Link to comment Share on other sites More sharing options...
Chris Woodhouse Posted June 22, 2008 Report Share Posted June 22, 2008 All you're after is a flange size, like said before your local bike shop should be able to help or tarty bikes simply tell them the hub, rim and hole of the rim or if they are confused of the hub just tell them the flange size rim and hole. Chris. Quote Link to comment Share on other sites More sharing options...
