nek0 Posted May 31, 2008 Report Share Posted May 31, 2008 What size adaptors do I need for Czar free trials frame with hifi fork? Hope trials 200mm front and back. Quote Link to comment Share on other sites More sharing options...
craigjames Posted May 31, 2008 Report Share Posted May 31, 2008 you wont need adaptors if you're buying them new, as the mono trial has a different calliper for each size of rotor (correct me if this has changed). you'll need a 160mm calliper and a2 00mm rotor for the rear (as the frame has a plus 40 mount) and a 200mm calliper and rotor for the front. if you're not buying them new, what rotors did each brake originally come with? Quote Link to comment Share on other sites More sharing options...
nek0 Posted May 31, 2008 Author Report Share Posted May 31, 2008 They will be new, just want to make sure I have the correct adaptors Thanks! Quote Link to comment Share on other sites More sharing options...
craigjames Posted May 31, 2008 Report Share Posted May 31, 2008 looking at the tarty website they come with a plus 20 adaptor for the front and a plus 40 for the rear, you'll only need the front for your forks. Quote Link to comment Share on other sites More sharing options...
