Tro dig inte Posted May 31, 2008 Report Share Posted May 31, 2008 Hi, I´m riding a koxx xtp 2 Dual Disc at the moment and unfortunately I warped my rear disc... So here comes the question, Its 155mm in diameter, is a 160mm disc going to fit? In that case, witch one do you prefer? appreciate the help:P Quote Link to comment Share on other sites More sharing options...
PaRtZ Posted June 1, 2008 Report Share Posted June 1, 2008 I honestly can't say for one...but surely you can tweak the position of the pads hitting the disc using your tensioners? I was running a BB7 rear on my hydroxx and it was so confusing to set up right. It takes time but it does work eventually. Ideally you want the wheel as far forward in the dropouts (slack chain) so you have the largest amount of contact with the pads + disc. Im pretty sure it would work, but I wouldn't bet my life on it. Maybe £30 Quote Link to comment Share on other sites More sharing options...
