Callum-Luvs-Trials Posted May 27, 2008 Report Share Posted May 27, 2008 I know the Ko-bikes have the problem with the brake mounts being to high, That being the case I cant have the chain tension right because I need my wheel all the way forward to get the pads set up propely. I'm using a 12 tooth rear sprocket on the rear and i'm wondering if a 13 tooth sprocket on the rear would help my problem? Making the wheel have more tension being further forward? I dont really mind about the ratio part. Any replies would be nice thanks. Quote Link to comment Share on other sites More sharing options...
Ash-Kennard Posted May 27, 2008 Report Share Posted May 27, 2008 do it fool Quote Link to comment Share on other sites More sharing options...
Callum-Luvs-Trials Posted May 27, 2008 Author Report Share Posted May 27, 2008 do it fool Do you think it will work? Quote Link to comment Share on other sites More sharing options...
Tango Posted May 27, 2008 Report Share Posted May 27, 2008 Ofc it will bigger rear cog = more links on it = better tension Quote Link to comment Share on other sites More sharing options...
Callum-Luvs-Trials Posted May 27, 2008 Author Report Share Posted May 27, 2008 Ofc it will bigger rear cog = more links on it = better tension Thanks. Does anyone know where to get a cheapish 13 tooth screw on cog? Tartybikes do them but there abit to ££ for me. Thanks. Quote Link to comment Share on other sites More sharing options...
