spartan Posted May 24, 2008 Report Share Posted May 24, 2008 Ok so the bike i just bought used has the monty version of the 07 hope mono trials, the grey and silver ones. They both needed a bleed so i bled them using a wrench and a bottle of fluid. But now they seem to be leaking from the lever, im pretty sure that its from the resivoir cap and not the cable fitting but it could be either. Has any one hit this problem before, what should i do about it because the feel of the lever keeps changing and its really annoying!! Quote Link to comment Share on other sites More sharing options...
Skoze Posted May 24, 2008 Report Share Posted May 24, 2008 If it's coming from under the reservoir cap, my first guess would be that the diaphram has gone. Happened to my first one! Easy fix, like £2 from tarty, just take the cap off, remove old diaphram, put in new one, put cap back on, bleed Matt Quote Link to comment Share on other sites More sharing options...
..::littlesam::.. Posted May 24, 2008 Report Share Posted May 24, 2008 (edited) How much is coming out? Because it is normal for a bit come come out as there it a little slot/hole were its allows a bit out after the bleed. Sam X Edited May 24, 2008 by ..::littlesam::.. Quote Link to comment Share on other sites More sharing options...
spartan Posted May 24, 2008 Author Report Share Posted May 24, 2008 Like it was coming out alot, but i realized the cap was on backwards so i switched them around and now the front is fine and the rear is still leaking a bit but ill see how bad it is. Quote Link to comment Share on other sites More sharing options...
