Caleb Posted May 22, 2008 Report Share Posted May 22, 2008 1st question: I have some fsa v drive extreme cranks that have removable pedal inserts, i presume these are the same thread size as the tensile pedal inserts?2nd question: Is there a special 4 pronged tool to get these off? like a miniature freewheel tool? ive been trying all the methods so far to remove them with no avail.blow torchhammer and centre punchlubed it etc Quote Link to comment Share on other sites More sharing options...
forteh Posted May 22, 2008 Report Share Posted May 22, 2008 Think you will need a peg spanner to undo the pedal inserts Can make one from a couple of steel plates, a bolt and a couple of pins (small allen screws?); or just go beg/borrow/steal one Quote Link to comment Share on other sites More sharing options...
Tomm Posted May 22, 2008 Report Share Posted May 22, 2008 1st question: I have some fsa v drive extreme cranks that have removable pedal inserts, i presume these are the same thread size as the tensile pedal inserts?I wouldn't assume that unless you know for certain. I have no idea but I wouldn't be surprised if they were completely different. Quote Link to comment Share on other sites More sharing options...
Caleb Posted May 22, 2008 Author Report Share Posted May 22, 2008 i see what you mean, only i cant find any information on the fsa inserts, i'll wait for my tensiles to come and will try and compare, if they look totally wrong ill buy some, otherwise i might end up cutting the ol' fsa cranks off to get the inserts hehe Quote Link to comment Share on other sites More sharing options...
Netherking Posted May 22, 2008 Report Share Posted May 22, 2008 1st question: I have some fsa v drive extreme cranks that have removable pedal inserts, i presume these are the same thread size as the tensile pedal inserts? 2nd question: Is there a special 4 pronged tool to get these off? like a miniature freewheel tool? ive been trying all the methods so far to remove them with no avail. blow torch hammer and centre punch lubed it etc btw pretty sure tensile have a 2 holes on there inserts. Quote Link to comment Share on other sites More sharing options...
Caleb Posted May 22, 2008 Author Report Share Posted May 22, 2008 yeah i know about the tensiles have two holes, but that shouldn't effect anything really, as i wont ever need to take them out. Quote Link to comment Share on other sites More sharing options...
psycholist Posted May 23, 2008 Report Share Posted May 23, 2008 Only question that springs too mind for me is why do you want to take the inserts out? Is it just curiosity or are you planning on using the inserts somewhere - are the pedals stuck in them? Quote Link to comment Share on other sites More sharing options...
Caleb Posted May 23, 2008 Author Report Share Posted May 23, 2008 just want to see if the pedal inserts from my fsa's will fit into my tensiles (as they currently dont have any inserts) so i can save some money Quote Link to comment Share on other sites More sharing options...
psycholist Posted May 23, 2008 Report Share Posted May 23, 2008 If tensile will replace broken cranks under warranty I wouldn't modify them at all. If the thread in the tensiles are already f**kered then this sounds like a very good plan to get the cranks going... If you can get pictures I'm quote curious as to what way they're fitted... Quote Link to comment Share on other sites More sharing options...
Caleb Posted May 24, 2008 Author Report Share Posted May 24, 2008 theyre unfortunately not the same size. i bought the tensiles cheap as there was no inserts included. therefore i presumed the ones off my spare fsa cranks would fit, saving me some pennies but they dont . Quote Link to comment Share on other sites More sharing options...
