Xandor!1990 Posted May 20, 2008 Report Share Posted May 20, 2008 Okay on my rear mount i had a siezed mount bolt and my alan key had rounded off in it. So i had hacksawed the head off the bolt and had tryed moving the bolt with a pair of mole grips, then the bolt had snapped so i was left with a bolt stuck right in the mount. What should i do?cheers, Xan Quote Link to comment Share on other sites More sharing options...
Revolver Posted May 20, 2008 Report Share Posted May 20, 2008 So the bolt is stuck in the mount.If i were you, I would cry.You could drill out the bolt and then helicoil the hole, otherwise. Quote Link to comment Share on other sites More sharing options...
Anton Posted May 20, 2008 Report Share Posted May 20, 2008 ive found in the past if you center punch the center of the snapped bolt and then drilling into it with a small drill piece you can usually undo the remaining bolt with a alan key. Quote Link to comment Share on other sites More sharing options...
