echo_rob Posted May 20, 2008 Report Share Posted May 20, 2008 Hey there,Had a hope mono trial for some time now. Had some problems with it, but it worked O.KNow I know this sounds noobish. But basically I turned the bike upside down and pumped it. I believe it drew air and now whatever I do it will not bleed or pressurise in any way.Any help?Also, whats up with the diaphragms, they just expand and curl up in the reservoir??thanksrob Quote Link to comment Share on other sites More sharing options...
esfrost Posted May 20, 2008 Report Share Posted May 20, 2008 Heres some help from Hope: http://www.hopegb.com/page_mep_force_35.html Quote Link to comment Share on other sites More sharing options...
echo_rob Posted May 20, 2008 Author Report Share Posted May 20, 2008 sorry no help. That just tells you how to roll the diaphragm. When I bleed it the actual level does not drop when I release the lever. No pressure at all or anything.thanksrob Quote Link to comment Share on other sites More sharing options...
esfrost Posted May 20, 2008 Report Share Posted May 20, 2008 One of my friends ha a similar problem. He had to take apart the lever and clean it, there was some kind of pluggage. He managed to fix it and it still works pretty well. You can ask hope about your problem, they will help. Quote Link to comment Share on other sites More sharing options...
echo_rob Posted May 20, 2008 Author Report Share Posted May 20, 2008 any other help from anyone?thanksrob Quote Link to comment Share on other sites More sharing options...
Matthew62 Posted May 20, 2008 Report Share Posted May 20, 2008 (edited) I take it you are opening up the bleed nipple on the caliper? You've got to open the caliper bolt whilst the lever is being pushed down, then hold the lever down, and tighten up the bolt. Then as you release (slowly), the fluid is drawn through. Is that what you're doing? Edited May 20, 2008 by Matthew62 Quote Link to comment Share on other sites More sharing options...
echo_rob Posted May 21, 2008 Author Report Share Posted May 21, 2008 yes, I can bleed a brake. I am doing it right.any more help dudes?thanksrob Quote Link to comment Share on other sites More sharing options...
