dan_addison Posted May 16, 2008 Report Share Posted May 16, 2008 Could some young stud explain them? simple as possible please cheers Dan XxX Quote Link to comment Share on other sites More sharing options...
JD™ Posted May 16, 2008 Report Share Posted May 16, 2008 the strings are each represented by a line. the high e (thinnest) at the top and the the low e (thickest) at the bottom. The numbers refer to the fret to play on that string, with 0 being open. e.g.------------------------------------------------------------------------------------------0-----------means play the low e open.The strings can denote non standard tuning by stating the tuning of that string to the left of the tab line.e.g.d -----------------a -----------------g -----------------d --------5---5---a ----3------------d -----------------means play the 3rd fret of the a string, then the 5th fret of the middle d string twice.hope this helps to start. Quote Link to comment Share on other sites More sharing options...
JonZebdi Posted May 16, 2008 Report Share Posted May 16, 2008 indeed /\ what he said - good eplanation!!Jon Quote Link to comment Share on other sites More sharing options...
TomR Posted May 16, 2008 Report Share Posted May 16, 2008 And google or any tab site would also explain. Quote Link to comment Share on other sites More sharing options...
hI-OOPS-CAPS Posted May 17, 2008 Report Share Posted May 17, 2008 (edited) you can youtube these to help explain tab, ~ is vibrato, b is bend, r is release - b r generally used together, . is palm mute, s slide, t fingertap. and ofcourse p pulloff and h hammeronall quite easy to pick up except vibrato, well vibratos hard for me anyway Edited May 17, 2008 by moctezuma Quote Link to comment Share on other sites More sharing options...
