davey1991 Posted May 13, 2008 Report Share Posted May 13, 2008 I'm hoping to soon have a new 20", i would like to start customising it but before that i'd like to know a few things.What would be the best wheels to get, compatible with HS33's?What are the best tyres, i know most use maxxis but are these the best?What pressure should i be running my tyres at?What forks should i concider, light weight and strong?Are there any good, cheap and lightweight frames on the market that are worth looking at, and if so what?Thanks, Davey. Quote Link to comment Share on other sites More sharing options...
Scott Norman Posted May 13, 2008 Report Share Posted May 13, 2008 I'm hoping to soon have a new 20", i would like to start customising it but before that i'd like to know a few things.What would be the best wheels to get, compatible with HS33's?What are the best tyres, i know most use maxxis but are these the best?What pressure should i be running my tyres at?What forks should i concider, light weight and strong?Are there any good, cheap and lightweight frames on the market that are worth looking at, and if so what?Thanks, Davey.All wheels are. as long has forks have 4 bolt mounts.Try all tyres.20 psi in back and bout 30 in frontKo m1 forks.DOB magnesium frame.But trust me dont bother untill you can properly ride trials. i only started geting better parts for my bike after about a year of riding. Just get a £300 bike and stick with it till you get a bit better. Scott. Quote Link to comment Share on other sites More sharing options...
Scott Norman Posted May 13, 2008 Report Share Posted May 13, 2008 And then you might get called all the bike none of the ride. Quote Link to comment Share on other sites More sharing options...
