Danny Kearns Posted May 9, 2008 Report Share Posted May 9, 2008 Hey guys, I've got a Try-all rim on at the moment, now, these thing just don't like drop gaps or heavy riders at all.So, Im not wanting my backend to feel heavier...So if i change to a Echo 07 from a Try-all will i really feel the difference ?It's stock by the way, I think the Echo 07's are 100 grams heavier.Thanks,Danny. Quote Link to comment Share on other sites More sharing options...
Ben John-Hynes Posted May 9, 2008 Report Share Posted May 9, 2008 Can you not try and get hold of an older echo rim?05 or 06.Other that that, there's not a lot that can be done to adjust the feel of the back end. Quote Link to comment Share on other sites More sharing options...
Danny Kearns Posted May 9, 2008 Author Report Share Posted May 9, 2008 Trim the tyre a bit to save the few grams?Other than that, ride it Already cut the side tred off Had to cause a 2.5 doesn't fit in controls if you don't.05 Rims are too thin and 06 are made of cheese. Quote Link to comment Share on other sites More sharing options...
Mark W Posted May 9, 2008 Report Share Posted May 9, 2008 If you're talking stock, if you bear in mind that 100g is going to be spread around the entire circumference of that rim, I doubt you'll really feel it. If you do, you'll get used to it within a ride, pretty much. It'll be reet! Quote Link to comment Share on other sites More sharing options...
Matthew_Gibson Posted May 9, 2008 Report Share Posted May 9, 2008 would think you'll be able to tell. unless you put it on scales. Why not get a front echo rim its only 40mm wide though. probably as strong as the rear too Quote Link to comment Share on other sites More sharing options...
eskimo Posted May 9, 2008 Report Share Posted May 9, 2008 Depends how weight sensitive you are. Most people wouldn't notice.But the Echo 07 rims aren't all there cracked up to be either. If you were to run a harder pressure the Try-All should be fine. Isit flat spots your having problems with? Quote Link to comment Share on other sites More sharing options...
Skoze Posted May 9, 2008 Report Share Posted May 9, 2008 My bike seems to have gone nuts on the lets see how heavy this back end can be-o-meter.I can't really tell exactly how much the difference in the rim is, as i now have the rim, a king and all the large mono trial paraphenalia (sp?) on the back.As Mark said, that 100g is spread out a fair bit, so i reckon it'd feel a bit different, but nowt majorWhack one on there boyo! You're a bit of a beast anyway Matt Quote Link to comment Share on other sites More sharing options...
Danny Kearns Posted May 9, 2008 Author Report Share Posted May 9, 2008 Depends how weight sensitive you are. Most people wouldn't notice.But the Echo 07 rims aren't all there cracked up to be either. If you were to run a harder pressure the Try-All should be fine. Isit flat spots your having problems with?Well, this wheel i have on a brought Second hand, the wheelbuild wasn't the greatest when i got it, flat spotted and buckled. So went over it with a spoke key and got it remotely better. Since i've been riding on it, ive managed to put 3 dents in it and made the flatspot abit bigger.My bike seems to have gone nuts on the lets see how heavy this back end can be-o-meter.I can't really tell exactly how much the difference in the rim is, as i now have the rim, a king and all the large mono trial paraphenalia (sp?) on the back.As Mark said, that 100g is spread out a fair bit, so i reckon it'd feel a bit different, but nowt majorWhack one on there boyo! You're a bit of a beast anyway MattHaha cheers dude, Im just un-sure. Weight of a bike doesn't matter to me on a mod, but on a stock it means alot. Quote Link to comment Share on other sites More sharing options...
sidehop Posted May 9, 2008 Report Share Posted May 9, 2008 Run a front rim back there man...They hold up. Trust me.Travs got a front on the back. Quote Link to comment Share on other sites More sharing options...
totaltrials Posted May 9, 2008 Report Share Posted May 9, 2008 I think if you need a stronger rim it's worth the extra weight especially as you don't need to worry about it after extra gap.I doubt you'll feel the difference with just changing the rim, but if you change other bits it'll all add up and you'll notice it. Quote Link to comment Share on other sites More sharing options...
N.Wood Posted May 9, 2008 Report Share Posted May 9, 2008 Don't be such a basher?You won't feel 100g, especially on the rear. Only the difference from going to a new tyre from a bald one. Quote Link to comment Share on other sites More sharing options...
Greetings Posted May 9, 2008 Report Share Posted May 9, 2008 The difference can be greater, it depends on how much your rim weighs. The heaviest anodized 07 Echo I've come across was 899g, the lightest Tryall was 690 though some weigh even less. You will notice a ~200g difference.Don't get a front Echo, it might be strong enough but it weighs about the same as a TryAll 47mm rim. Quote Link to comment Share on other sites More sharing options...
casualjoe Posted May 9, 2008 Report Share Posted May 9, 2008 Give a Neon rim a try, they have double thickness sidewalls and weigh the same as a tryall and they are on sale at the mo and you wont need to buy new spokes, thats what I want to do anyway but I would like to read some reviews of them before I dive in there, I cant find anything on them. Quote Link to comment Share on other sites More sharing options...
Mark W Posted May 10, 2008 Report Share Posted May 10, 2008 If you're running a 2.5" tyre on the back, a front rim would be asking for pinches to the max, and some pretty wanktastic tyre rollage if you ride anything other than right angle edged walls, or nice rails. Quote Link to comment Share on other sites More sharing options...
chrishayton Posted May 10, 2008 Report Share Posted May 10, 2008 Already cut the side tred off Had to cause a 2.5 doesn't fit in controls if you don't.05 Rims are too thin and 06 are made of cheese.erm my 2.5 minion fitted perfectly on tryall in a control frame danny? Quote Link to comment Share on other sites More sharing options...
Danny Kearns Posted May 10, 2008 Author Report Share Posted May 10, 2008 (edited) erm my 2.5 minion fitted perfectly on tryall in a control frame danny?My control must have serious issue's then EDIT: Btw dude, do you have your bike with you at Uni ? Could go for a ride soon Edited May 10, 2008 by Danny Kearns Quote Link to comment Share on other sites More sharing options...
Pauly Posted May 10, 2008 Report Share Posted May 10, 2008 Depends how weight sensitive you are. Most people wouldn't notice.But the Echo 07 rims aren't all there cracked up to be either. If you were to run a harder pressure the Try-All should be fine. Isit flat spots your having problems with?dissagree son my echo 07 has taken a right beating from me and lets be ohnest im not exactly smooth... the only time it did start to give in was when my spokes were loose but apart from that i was quite supprised how well these badbois held up.drunk anyways so who cares lol Paul Quote Link to comment Share on other sites More sharing options...
eskimo Posted May 10, 2008 Report Share Posted May 10, 2008 dissagree son my echo 07 has taken a right beating from me and lets be ohnest im not exactly smooth... the only time it did start to give in was when my spokes were loose but apart from that i was quite supprised how well these badbois held up.drunk anyways so who cares lol PaulPauly you piss head All i said "But the Echo 07 rims aren't all there cracked up to be either."They don't like sideway impact at all. I've not fully tested mine yet though. Quote Link to comment Share on other sites More sharing options...
ben_travis Posted May 10, 2008 Report Share Posted May 10, 2008 Well i will answer the questions about a front echo rim on the rear (as i run one) Brilliant rim. I have had no problems with sideways roll, no problems with pinch punctures.I recently ground out the inner wall of the rim (to see about weight weenie ness) and still had no real problems. Although the rim is now dieing and as such i will be re-building my silver rim onto the bike.Its definately worth considering, as they hold a grind fairly well, and as someone said, its the same weight as a try-all, so you will not notice a difference in the weight, however u will have a strong rim. Quote Link to comment Share on other sites More sharing options...
