Ben H! Posted May 8, 2008 Report Share Posted May 8, 2008 hi people i seem to be having problems with my back wheel instead of the wheel being centered in the middle when you ride the bike it has a habit off moving over to one side and then rubbing against the chainstay at first i thought it was something to do with the axle bolts but i'm not 100% sure Quote Link to comment Share on other sites More sharing options...
monkeyseemonkeydo Posted May 8, 2008 Report Share Posted May 8, 2008 That's what the snail cams are for. Set the chain tension with the one on the right, get the wheel centred using the one on the left and then tighten everything up- should then stay in place. Quote Link to comment Share on other sites More sharing options...
Ben H! Posted May 8, 2008 Author Report Share Posted May 8, 2008 That's what the snail cams are for. Set the chain tension with the one on the right, get the wheel centred using the one on the left and then tighten everything up- should then stay in place.ok cheers Quote Link to comment Share on other sites More sharing options...
dirt jumper jake Posted May 8, 2008 Report Share Posted May 8, 2008 You might have bent the rear of your frame, happened to me on my jump bike. Quote Link to comment Share on other sites More sharing options...
Ben H! Posted May 8, 2008 Author Report Share Posted May 8, 2008 You might have bent the rear of your frame, happened to me on my jump bike.oh crap i hope not it's worth £610the frame looked ok though when i was fixing it Quote Link to comment Share on other sites More sharing options...
NileBrownâ„¢ Posted May 8, 2008 Report Share Posted May 8, 2008 You might have bent the rear of your frame, happened to me on my jump bike.I very much doubt that. Quote Link to comment Share on other sites More sharing options...
dirt jumper jake Posted May 9, 2008 Report Share Posted May 9, 2008 I very much doubt that.I dont its very easy to do, well on a jump bike anyway Quote Link to comment Share on other sites More sharing options...
higgzGU! Posted May 16, 2008 Report Share Posted May 16, 2008 hi there,that happened to a mate of mine and he put it to the local bike shop to fix it, Still happend but not as frecquintly if i remember corectly it was something to do with the wheel. He recently bought an echo wheel and since then it has'nt happened yet.Craig Quote Link to comment Share on other sites More sharing options...
Ben H! Posted May 16, 2008 Author Report Share Posted May 16, 2008 hi there,that happened to a mate of mine and he put it to the local bike shop to fix it, Still happend but not as frecquintly if i remember corectly it was something to do with the wheel. He recently bought an echo wheel and since then it has'nt happened yet.Craig cheers mate i've sorted it now, all down to a few washers. Quote Link to comment Share on other sites More sharing options...
higgzGU! Posted May 17, 2008 Report Share Posted May 17, 2008 cheers mate i've sorted it now, all down to a few washers.Alright that is good, How what was wrong were there not enough washers on it so it wasnt going tight enough, So it was moving ?Craig Quote Link to comment Share on other sites More sharing options...
basher Posted May 17, 2008 Report Share Posted May 17, 2008 You might have bent the rear of your frame, happened to me on my jump bike.A tip for you always look for the simple small solution first and then rule them out before you go thinking something like that and buying a new frame. The chances of a rear end twisting are slim and if they did you would see stress marks. Quote Link to comment Share on other sites More sharing options...
mobdrop Posted May 17, 2008 Report Share Posted May 17, 2008 hello, i have this http://www.tartybikes.co.uk/product.php?id=10265 and it works verry good, try to use them. Quote Link to comment Share on other sites More sharing options...
Ben H! Posted May 17, 2008 Author Report Share Posted May 17, 2008 hello, i have this http://www.tartybikes.co.uk/product.php?id=10265 and it works verry good, try to use them.thanks anyway mate but it's sorted cheers anyway Quote Link to comment Share on other sites More sharing options...
