Zoo_Python Posted May 6, 2008 Report Share Posted May 6, 2008 Hi guys.I am riding a zoo python with the onza hog drilled wheels and they are so heavy.So i am thinking of getting some lighter (any light tyers).If any of you lot know what will be the best.Thanks Steve. Quote Link to comment Share on other sites More sharing options...
eskimo Posted May 7, 2008 Report Share Posted May 7, 2008 I'd go with a Echo Rear Fixed on a Try-All or DX32. That's what i'm running at the moment. With a Monty tyre.Front wise i'm running a Pro2 Disk on a Monty Champaigne with Monty tyre. I think the Try-All tyre is lighter, but i will be buying one for the grip anyway.It does all depend on how much strength you want. The DOB rims are now getting alot of negative feedback as well so probably not the best choice. Try and use alloy nipples for both wheels and double butted spokes for the front. (they're not available for rear yet), unless your on 36h 4 cross.You won't be able to knock much weight off the rear i'm affraid due to the massive tyre we run, but the front wheel is defiently worth some research. Quote Link to comment Share on other sites More sharing options...
Dan x) Posted May 7, 2008 Report Share Posted May 7, 2008 well this is the wheel build im geting from trials ukEcho Front 20" Rim 07 - Fluro GreenEcho Rear 19" Rim 07 - Fluro GreenEcho Rim Tape - 20" (Set)VIZ Rear Fixed Hub 20" - GreenECHO Fixed 12T SprocketVIZ Non Disk Hub - GreenVIZ Rear White Spokes - 174mm (19" Wheels)VIZ Front White Spokes - Front 20"Neon Coloured Nipples - BlueItems: 10Subtotal: £209.00Postage: £5.00Total: £214.00^ ^good light wheels Dan, Quote Link to comment Share on other sites More sharing options...
Zoo_Python Posted May 7, 2008 Author Report Share Posted May 7, 2008 Thanks for the help as will come in very usfully well this is the wheel build im geting from trials ukEcho Front 20" Rim 07 - Fluro GreenEcho Rear 19" Rim 07 - Fluro GreenEcho Rim Tape - 20" (Set)VIZ Rear Fixed Hub 20" - GreenECHO Fixed 12T SprocketVIZ Non Disk Hub - GreenVIZ Rear White Spokes - 174mm (19" Wheels)VIZ Front White Spokes - Front 20"Neon Coloured Nipples - BlueItems: 10Subtotal: £209.00Postage: £5.00Total: £214.00^ ^good light wheels Dan, What is the website you are gotting all that stuff from as it sounds like a good buy.As might have to do that my self.Thanks agen Steve Quote Link to comment Share on other sites More sharing options...
Dan x) Posted May 7, 2008 Report Share Posted May 7, 2008 yes it isthey also build the build the wheel for £10 ech wheel Dan, Quote Link to comment Share on other sites More sharing options...
Danny Kearns Posted May 7, 2008 Report Share Posted May 7, 2008 yes it isthey also build the build the wheel for £10 ech wheel Dan, I do them for the price of a drink Quote Link to comment Share on other sites More sharing options...
Dan6061 Posted May 7, 2008 Report Share Posted May 7, 2008 Echo 07 rims are heeeaaavvvyyyy. Quote Link to comment Share on other sites More sharing options...
Ben John-Hynes Posted May 7, 2008 Report Share Posted May 7, 2008 well this is the wheel build im geting from trials ukRim 07 - Fluro GreenRim 07 - Fluro GreenHub 20" - GreenHub - GreenWhite SpokesWhite SpokesNipples - Blue Thanks for the help as will come in very usfully What is the website you are gotting all that stuff from as it sounds like a good buy.As might have to do that my self.Thanks agen SteveHe used www.trials-uk.co.uk for that mate! Quote Link to comment Share on other sites More sharing options...
Dan x) Posted May 7, 2008 Report Share Posted May 7, 2008 I do them for the price of a drink i'd ask you but you never talk to me on msn Quote Link to comment Share on other sites More sharing options...
0zzy Posted May 7, 2008 Report Share Posted May 7, 2008 well this is the wheel build im geting from trials ukEcho Front 20" Rim 07 - Fluro GreenEcho Rear 19" Rim 07 - Fluro GreenEcho Rim Tape - 20" (Set)VIZ Rear Fixed Hub 20" - GreenECHO Fixed 12T SprocketVIZ Non Disk Hub - GreenVIZ Rear White Spokes - 174mm (19" Wheels)VIZ Front White Spokes - Front 20"Neon Coloured Nipples - BlueItems: 10Subtotal: £209.00Postage: £5.00Total: £214.00^ ^good light wheels Dan, light thats not exactly light to be honest. echo rims are heavy for a start. Quote Link to comment Share on other sites More sharing options...
Dan x) Posted May 7, 2008 Report Share Posted May 7, 2008 compared to onza rims. Quote Link to comment Share on other sites More sharing options...
Danny Kearns Posted May 7, 2008 Report Share Posted May 7, 2008 (edited) To be honest, Echo 07 rims probably are heavier than Onza rims. Edited May 7, 2008 by Danny Kearns Quote Link to comment Share on other sites More sharing options...
eskimo Posted May 7, 2008 Report Share Posted May 7, 2008 Apparently the Echo Rear is heavier. Only by 10 to 20 grams though.Them white spokes aren't double butted either. I'd be suprised if they were.Neon coloured nipples suck. Get some Prolite ones. They're like a fiver for 100.And you should buy a Echo hub instead on that Viz. Once you've bought sprocket and snail cams it doesn't work out much cheaper. The Echo is lighter and more bearings. Also a splined cog instead of an annoying screw on one. Quote Link to comment Share on other sites More sharing options...
Dan x) Posted May 7, 2008 Report Share Posted May 7, 2008 ahh nice thanks guyssort a budgit Quote Link to comment Share on other sites More sharing options...
Alex-Mitchinson Posted May 7, 2008 Report Share Posted May 7, 2008 Them wheels are really heavy.Ideally you want try-all hubs, front dob rim and monty on the back. Try-all hubs are really expensive though, however you can get neon hubs for like half the price and theyre only a bit heavier. Quote Link to comment Share on other sites More sharing options...
Muel Posted May 8, 2008 Report Share Posted May 8, 2008 Or Monty TI hubs, which are pretty light and work well. The Try-All H hubs are the lightest and look good, can't comment on the stregnth yet though as I have never heard of any breaking. Quote Link to comment Share on other sites More sharing options...
Ladd Posted May 8, 2008 Report Share Posted May 8, 2008 Get something like this.Kris Holm Rear Rim.Muntiny SpokesGold Profile FreehubGold Prolite NipplesTarty BuildMaxxis CC tyreCheng TubeEcho 2005 Cnc rim Hope Pro 2 GoldMuntiny spokesGold Prolite nipplesTarty BuildMaxxis CC tyre.Cheng Tube. Quote Link to comment Share on other sites More sharing options...
Callum-Luvs-Trials Posted May 8, 2008 Report Share Posted May 8, 2008 Get something like this.Kris Holm Rear Rim.Muntiny SpokesGold Profile FreehubGold Prolite NipplesTarty BuildMaxxis CC tyreCheng TubeEcho 2005 Cnc rim Hope Pro 2 GoldMuntiny spokesGold Prolite nipplesTarty BuildMaxxis CC tyre.Cheng Tube.I think i know someone who uses that setup? Quote Link to comment Share on other sites More sharing options...
Ladd Posted May 8, 2008 Report Share Posted May 8, 2008 I think i know someone who uses that setup?no lol i dont have a gold front hub or gold nipples Quote Link to comment Share on other sites More sharing options...
Maximus Posted May 8, 2008 Report Share Posted May 8, 2008 (edited) compared to onza rims.Onza have 50g + added to them, because they are eyeleted, which help create a stronger wheel build, to quote tarty, "Eyeleted spoke seats allows for higher spoke tensions and thus a significantly stronger wheel when compared to competitor's un-eyeleted rims" other than that there quite light when you think about it, even with this they are still lighter that the echo rims your saying, yeah Edited May 8, 2008 by Maximus Quote Link to comment Share on other sites More sharing options...
Ben H! Posted May 8, 2008 Report Share Posted May 8, 2008 perhaps a good rim choice would be try all on the front and echo on the back, i use try all on front and rear and they seem fine Quote Link to comment Share on other sites More sharing options...
bart Posted May 8, 2008 Report Share Posted May 8, 2008 (edited) Get a try-all bmx front rim same colors as the trial stuff a bit narrow but 350 gr. and it s cheaper than the trial rimrear just get a driled DX 32 and a quando or echo hub. Edited May 8, 2008 by bart Quote Link to comment Share on other sites More sharing options...
Daniel C Posted May 8, 2008 Report Share Posted May 8, 2008 front and back tryall rims muntiny spokes + nipplesecho hubs (cheap on select bikes i think)creepy crawler tyres Quote Link to comment Share on other sites More sharing options...
Zoo_Python Posted May 8, 2008 Author Report Share Posted May 8, 2008 Selectbikes.comRear echo hub (Fixed) 72.00 (Green)Fornt echo 28.99 (green)total 100.97Tartybikes.co.ukTry-all front rim 35.00 (White)Try-all rear rim 39.00 (white)Halo nipples 36nipples at 8.00 (Green)Trialtech spokes 15.00 for one wheel (White)Try-all rim tape 3.00 each (Black)total 131.00 plush 5.00 for p&pIts a nice build as i am thinking of getting it my self. Quote Link to comment Share on other sites More sharing options...
