spaceman Posted May 6, 2008 Report Share Posted May 6, 2008 Would a Tioga DH rim work with the hs33? I'm aware that it's designed for disc only. I heard that it would work if you grind it.But my question is, would it work if I don't grind the rim? Anyone using it with a hs33? Quote Link to comment Share on other sites More sharing options...
basher Posted May 6, 2008 Report Share Posted May 6, 2008 It no usually the surface finish thats the problem with disk only rims its the profile of the rim, as there is no brakeing surface as the wall is usually at an angles. Not sure what the profile is like on a tioga, but if its like mavics then no you cant. Quote Link to comment Share on other sites More sharing options...
Luke Rainbird Posted May 6, 2008 Report Share Posted May 6, 2008 I had those rims on my 24", and ran a set of Zoo! pads (original compound) with a water bled maggie, and it was intense Should be fine I would imagine - I didn't bother to grind/remove the coated layer, just let the brake wear through it slowly! Quote Link to comment Share on other sites More sharing options...
Alex Dark Posted May 6, 2008 Report Share Posted May 6, 2008 i reckon you'd be fine...it looks to be the same profile as a bmf or dx-32 Quote Link to comment Share on other sites More sharing options...
spaceman Posted May 6, 2008 Author Report Share Posted May 6, 2008 Oh goody, thank you all very much! Quote Link to comment Share on other sites More sharing options...
Tomm Posted May 6, 2008 Report Share Posted May 6, 2008 It works fine (I'm running one at the moment). Quote Link to comment Share on other sites More sharing options...
