cox. Posted May 5, 2008 Report Share Posted May 5, 2008 I was looking on heatsinkbikes.com at the pads, and im looking to get a pair of coust pads and i saw there was two types:Cnc backens with materialPlastic backens with materialDo the cnc backens actually make any defference to the performance of the pad or is it just looks? Thanks coxy.x Quote Link to comment Share on other sites More sharing options...
rudirudirudirudirudi Posted May 5, 2008 Report Share Posted May 5, 2008 cnc backings give a much firmer feel to the lever. apparently the plastic backings give more braking power because of its ability to flex which means you can squeeze the lever more or something.... this im unsure of .... all i know is that it feels better. Quote Link to comment Share on other sites More sharing options...
Headley Posted May 5, 2008 Report Share Posted May 5, 2008 Cnc backings give a much firmer feel to the brake and also pad wear is more even. If u've got cash I suggest investing in a pair. Quote Link to comment Share on other sites More sharing options...
NileBrown™ Posted May 6, 2008 Report Share Posted May 6, 2008 However there are drawbacks to CNC backings, your not meant to use them with Deng brakes as it invalidates the warrenty as some have been known to break the prongs on the slaves.However plastic ones are fine in my opinion as ive never had any trouble with them. Quote Link to comment Share on other sites More sharing options...
Alex Dark Posted May 6, 2008 Report Share Posted May 6, 2008 i really dont see the point of cnc backings....ive never used a brake with cnc backings that feels significantly better thsn plsccy backings...its just not worth it Quote Link to comment Share on other sites More sharing options...
PaddockPark Posted May 6, 2008 Report Share Posted May 6, 2008 Cnc backings give a much firmer feel to the brake and also pad wear is more even. If u've got cash I suggest investing in a pair. agree, anyways coust pads are good with or without CNC so it's your choice Quote Link to comment Share on other sites More sharing options...
Ben John-Hynes Posted May 6, 2008 Report Share Posted May 6, 2008 You were on the website,Yet you still call them "backens"?Anyway, I don't really see the point in cnc ones, too expensive for the small difference they make! Quote Link to comment Share on other sites More sharing options...
Ashley-Wood Posted May 6, 2008 Report Share Posted May 6, 2008 Well my mate had a set of coust pads and his wear rate wasnt the best as he only had them for a few weeks this is with the cnc so iwould suggest plastic backings, also your lever will felll smoother and will not have as hard feel when braking. but people say that the wear of the pad is straighter with cnc this is because the cnc backings cannot flex as much which means there will not be a nice groove in middle of pad giving you all the material you need to brake, unlike the plastic it forms a little groove which will affect your performance slightly as you will not have all the material working at its best so i say if you can afford 30 odd quid then go for it Quote Link to comment Share on other sites More sharing options...
N.Wood Posted May 6, 2008 Report Share Posted May 6, 2008 My CNC backens made an annoying clunk as they returned into the slave. They were on heatsink reds which, it appeared, are useless pads.Didn't think they felt overly stiffer, but if i look at my plastic backens on my Cousts they do flex a little. Quote Link to comment Share on other sites More sharing options...
Guest Posted May 6, 2008 Report Share Posted May 6, 2008 (edited) ran heatsinks reds for a few weeks before i went dual disc. they felt really solid with a water bleed. wouldnt want to use plastic backings again if i still ran maggys. Edited May 6, 2008 by Bearded Midget Quote Link to comment Share on other sites More sharing options...
Alex Dark Posted May 7, 2008 Report Share Posted May 7, 2008 i use plastic backings and they're fine to be honest, if i could get some cnc'd cheap then i'd get some......but i cant see that they're worth the money over the standards Quote Link to comment Share on other sites More sharing options...
ilikeriding Posted May 7, 2008 Report Share Posted May 7, 2008 plastic backings are plain shit, every set of pads ive ever used will have worked 10x better with cnc Quote Link to comment Share on other sites More sharing options...
onzamann07 Posted May 7, 2008 Report Share Posted May 7, 2008 i have found with plastic backings is that they crack? and because it can flex the pad material tends to try and roll off the backing which is what my koxx browns done Quote Link to comment Share on other sites More sharing options...
max-t Posted May 8, 2008 Report Share Posted May 8, 2008 My CNC backens...Hahaha Quote Link to comment Share on other sites More sharing options...
