FOX355-luke Posted May 4, 2008 Report Share Posted May 4, 2008 need a little help with my cones on my rear wheel. every time i tighten them about half an hour later they come loose, so when i ride along it rubs on the pads. any suggestions? Quote Link to comment Share on other sites More sharing options...
banananana Posted May 4, 2008 Report Share Posted May 4, 2008 Use a bit of loctite and tighten them as much as possible. Quote Link to comment Share on other sites More sharing options...
NileBrown™ Posted May 4, 2008 Report Share Posted May 4, 2008 (edited) Well your obviously not tightening them up correctly, the cones have two nuts which should tight up against each other. So tighten your cones up to where you want it then tighten the other nut against it to prevent it from coming loose. Edited May 4, 2008 by NileBrown Quote Link to comment Share on other sites More sharing options...
eskimo Posted May 5, 2008 Report Share Posted May 5, 2008 Sorted yet??I'll explain a little more. Each side has 2 nuts on. One being the cone and the other the locking nut. The cones need to tighten up into the bearings enough so the wheel doesn't move about, but only rolls smoothly on the bearings. Therefore this should be hand tight.Then you need a cone spanner. At about £4 they're not expensive. Use that cone spanner (on the cone) and another spanner on the lock nut then tighten together. Now the other side. Try and keep the cone tightened enough against them bearings before you lock the cone nut up against the lock nut. If the bearings feel unsmooth, add some more grease for quick releaf on the bearings or take the bearings out and clean them all then add some fresh grease. Quote Link to comment Share on other sites More sharing options...
tris Posted May 5, 2008 Report Share Posted May 5, 2008 need a little help with my cones on my rear wheel. every time i tighten them about half an hour later they come loose, so when i ride along it rubs on the pads. any suggestions?yea loctites good but only tighten them up untill there is no play. if you overtightn them the bearings will not move smoothly.and dont bother with a cone spanner, a normal adjustable works out just fine , i find. Quote Link to comment Share on other sites More sharing options...
FOX355-luke Posted May 5, 2008 Author Report Share Posted May 5, 2008 well i already knew how to tighten them but i found out today that 1 side with the end cap to seal the bearings in has crumbled and now its in bits until i can find somewere or someone with a onza t-pro rear hub... if anyone has spares for sale or to donate ide be very greatful. Quote Link to comment Share on other sites More sharing options...
matt-echo team Posted May 5, 2008 Report Share Posted May 5, 2008 I have one it is in pretty good condition it just needs the cog swaping over as i managed to snap 1 of the teeth off.You can have it for free, we can organise for sometime during this week? Quote Link to comment Share on other sites More sharing options...
FOX355-luke Posted May 7, 2008 Author Report Share Posted May 7, 2008 yea sounds good mate when can i get it??? Quote Link to comment Share on other sites More sharing options...
Callum-Luvs-Trials Posted May 7, 2008 Report Share Posted May 7, 2008 Ask Muel, He knows away of doing a non-sealed hub so it runs smooth and so the cones don't come loose. Quote Link to comment Share on other sites More sharing options...
matt-echo team Posted May 8, 2008 Report Share Posted May 8, 2008 Is Friday evening ok for you? By then I will have it all ready to put onto your wheel. Is there anything else you are going to need? Quote Link to comment Share on other sites More sharing options...
Chandler Posted May 8, 2008 Report Share Posted May 8, 2008 sorry about the stupid question in advance.........I dont have grips for tightening up cones. They are just circles...Im running sealed hubs, does that mean I dont need to tighten them up?Or does it mean I have to take them apart to actually tighten up the cones.could someone explain please Quote Link to comment Share on other sites More sharing options...
matt-echo team Posted May 8, 2008 Report Share Posted May 8, 2008 chandler.... you will proberly find that if you take your wheel off and take out the skewer there may be an allen key hole... tighten this and i think it does the same job. Quote Link to comment Share on other sites More sharing options...
hI-OOPS-CAPS Posted May 9, 2008 Report Share Posted May 9, 2008 i do actually think they can be over tightened, so just nip them up and loctite Quote Link to comment Share on other sites More sharing options...
jsy trials matt Posted May 9, 2008 Report Share Posted May 9, 2008 Use a bit of loctite and tighten them as much as possible.for a sealed bearing hud, if not the it should only be about finger tight or your wheel will not spin to good Quote Link to comment Share on other sites More sharing options...
The Stig Posted May 10, 2008 Report Share Posted May 10, 2008 Use a bit of loctite and tighten them as much as possible.AND CRUSH THE BEARINGS?? haha anyway yeah alot of good advice i will not repeat them Quote Link to comment Share on other sites More sharing options...
