Help With Linux Please
NicP
well trying to get steam running,
I've got tahoma installed in the fonts section and gecko is on here but i try run the msi and all i get is.
and help would be appreciated :D
nic@nic-desktop:~$ wine '/home/nic/Desktop/SteamInstall.msi'
preloader: Warning: failed to reserve range 00000000-00010000
wine: could not load L"Z:\\home\\nic\\Desktop\\SteamInstall.msi": Bad EXE format for
nic@nic-desktop:~$ preloader: Warning: failed to reserve range 00000000-00010000
fixme:advapi:RegisterEventSourceW ((null),L"Bonjour Service"): stub
wine: Unhandled page fault on read access to 0x00000000 at address 0x4162b5 (thread 0012), starting debugger...
Unhandled exception: page fault on read access to 0x00000000 in 32-bit code (0x004162b5).
Register dump:
 CS:0073 SS:007b DS:007b ES:007b FS:0033 GS:003b
 EIP:004162b5 ESP:7e60c9e0 EBP:7e60ca38 EFLAGS:00010246(   - 00      -RIZP1)
 EAX:00000000 EBX:7ee0ea6c ECX:00000000 EDX:7ffd0000
 ESI:00122c78 EDI:00000000
Stack dump:
0x7e60c9e0:  00000000 7edfd160 00122c78 7edfd2c9
0x7e60c9f0:  00000000 00000000 00000000 7bc88444
0x7e60ca00:  00000000 7bc90ce0 7e60ca28 7bc33d21
0x7e60ca10:  00000002 7e60ca58 7bc906e8 00122cd0
0x7e60ca20:  001106d0 7bc88444 7edfd16b 7bc88444
0x7e60ca30:  00122c78 7edfd160 7e60ca48 7bc6af9e
Backtrace:
=>1 0x004162b5 in mdnsresponder (+0x162b5) (0x7e60ca38)
  2 0x7bc6af9e call_thread_entry_point+0xe() in ntdll (0x7e60ca48)
  3 0x7bc6b632 in ntdll (+0x5b632) (0x7e60cae8)
  4 0x7bc6b862 in ntdll (+0x5b862) (0x7e60d3d8)
  5 0xb7dad4fb start_thread+0xcb() in libpthread.so.0 (0x7e60d4c8)
0x004162b5: movl	0x0(%eax),%ecx
Modules:
Module	Address			Debug info	Name (56 modules)
PE	  400000-  457000	Export          mdnsresponder
ELF	7b800000-7b92c000	Deferred        kernel32<elf>
  \-PE	7b820000-7b92c000	\               kernel32
ELF	7bc00000-7bca4000	Export          ntdll<elf>
  \-PE	7bc10000-7bca4000	\               ntdll
ELF	7bf00000-7bf03000	Deferred        <wine-loader>
ELF	7e71f000-7e728000	Deferred        libxcursor.so.1
ELF	7e728000-7e72d000	Deferred        libxfixes.so.3
ELF	7e72d000-7e730000	Deferred        libxcomposite.so.1
ELF	7e730000-7e736000	Deferred        libxrandr.so.2
ELF	7e736000-7e73e000	Deferred        libxrender.so.1
ELF	7e73e000-7e741000	Deferred        libxinerama.so.1
ELF	7e741000-7e761000	Deferred        imm32<elf>
  \-PE	7e750000-7e761000	\               imm32
ELF	7e761000-7e766000	Deferred        libxdmcp.so.6
ELF	7e766000-7e77e000	Deferred        libxcb.so.1
ELF	7e77e000-7e780000	Deferred        libxcb-xlib.so.0
ELF	7e780000-7e867000	Deferred        libx11.so.6
ELF	7e867000-7e875000	Deferred        libxext.so.6
ELF	7e875000-7e87a000	Deferred        libxxf86vm.so.1
ELF	7e87a000-7e892000	Deferred        libice.so.6
ELF	7e892000-7e89a000	Deferred        libsm.so.6
ELF	7e8a9000-7e93f000	Deferred        winex11<elf>
  \-PE	7e8c0000-7e93f000	\               winex11
ELF	7e95a000-7e97b000	Deferred        libexpat.so.1
ELF	7e97b000-7e9a5000	Deferred        libfontconfig.so.1
ELF	7e9b4000-7e9c9000	Deferred        libz.so.1
ELF	7e9c9000-7ea39000	Deferred        libfreetype.so.6
ELF	7ea39000-7eadb000	Deferred        oleaut32<elf>
  \-PE	7ea50000-7eadb000	\               oleaut32
ELF	7eadb000-7eb3c000	Deferred        rpcrt4<elf>
  \-PE	7eaf0000-7eb3c000	\               rpcrt4
ELF	7eb3c000-7ebe0000	Deferred        ole32<elf>
  \-PE	7eb50000-7ebe0000	\               ole32
ELF	7ebe0000-7ec7b000	Deferred        gdi32<elf>
  \-PE	7ebf0000-7ec7b000	\               gdi32
ELF	7ec7b000-7edc2000	Deferred        user32<elf>
  \-PE	7eca0000-7edc2000	\               user32
ELF	7edc2000-7ee14000	Deferred        advapi32<elf>
  \-PE	7edd0000-7ee14000	\               advapi32
ELF	7ee14000-7ee27000	Deferred        libresolv.so.2
ELF	7ee27000-7ee45000	Deferred        iphlpapi<elf>
  \-PE	7ee30000-7ee45000	\               iphlpapi
ELF	7ee45000-7ee71000	Deferred        ws2_32<elf>
  \-PE	7ee50000-7ee71000	\               ws2_32
ELF	7ee71000-7ee7c000	Deferred        libnss_files.so.2
ELF	7ee7c000-7ee94000	Deferred        libnsl.so.1
ELF	7ee94000-7ee9d000	Deferred        libnss_compat.so.2
ELF	7ee9e000-7eea1000	Deferred        libxau.so.6
ELF	7efcc000-7eff1000	Deferred        libm.so.6
ELF	7eff6000-7f000000	Deferred        libnss_nis.so.2
ELF	b7c54000-b7c58000	Deferred        libdl.so.2
ELF	b7c58000-b7da7000	Deferred        libc.so.6
ELF	b7da8000-b7dc0000	Export          libpthread.so.0
ELF	b7dcf000-b7f05000	Deferred        libwine.so.1
ELF	b7f07000-b7f23000	Deferred        ld-linux.so.2
Threads:
process  tid      prio (all id:s are in hex)
0000000a
	0000000b    0
0000000c
	0000000e    0
	0000000d    0
0000000f (D) C:\Program Files\Bonjour\mDNSResponder.exe
	00000012    0 <==
	00000011    0
	00000010    0
Backtrace:
I'm thinking it's wine istell having a spaz.
But really not sure
NicP
Edited by NicP
