riddler Posted April 29, 2008 Report Share Posted April 29, 2008 well looking at my bike im going to be using a rim from my old bike soo it is used to a set of vee's on it, but say if i was to set it up with a disc brake would i need to do anything to the rim. what i mean is should the disc fit straight onto the rim or will i need to purchase fittings to arrange the disc onto the rim? bit of a newbie question but ill ask anyway. thanks Quote Link to comment Share on other sites More sharing options...
forteh Posted April 29, 2008 Report Share Posted April 29, 2008 Disk has nothing to do with the rim, aslong as you have a disk hub and tabs on your frame/forks then you can use a disk Quote Link to comment Share on other sites More sharing options...
riddler Posted April 29, 2008 Author Report Share Posted April 29, 2008 the forks are able to hold a disk, so as long as the hub is a disk hub then everything should fit fine?if thats the case lol i need a new hub Quote Link to comment Share on other sites More sharing options...
Alex Dark Posted April 30, 2008 Report Share Posted April 30, 2008 the forks are able to hold a disk, so as long as the hub is a disk hub then everything should fit fine?if thats the case lol i need a new hub yep a new hub is needed if it isnt disc compatible Quote Link to comment Share on other sites More sharing options...
