!Harris! Posted April 27, 2008 Report Share Posted April 27, 2008 Hi , was just Wondering if anybody knows how the Hope Pro 2 Trials rides like and if it is reliable, As I currently ride with a Standard hope pro 2 which is very reliable and strong Just with slightly less engagement than the Hope Pro 2 Trials. Wondering Wether to upgrade . ThanksNathan Quote Link to comment Share on other sites More sharing options...
Luke Rainbird Posted April 28, 2008 Report Share Posted April 28, 2008 The Pro IIt is a brilliant hub, and 99% of the times you see anyone mention a Pro II on here, that's the one they'll mean.With 48 engagement points, pawls engaging as 2 offset pairs (2 pawls at once, still a 24t ratchet ring but the offset means 48ep) it has double the engagement of the standard Pro II hub, meaning quicker pickup which is always nice.A few people had an issue with the '06 hubshell cracking. Hope responded to this by tweaking the design slightly, which, as far as I know, has pretty much totally eliminated this problem.If you've been running the standard for a while, you should know pretty much what you're in for with the trials model. Not 100% on the exact differences, but I think there may be a more solid axle to the trials one.Can't fault mine Quote Link to comment Share on other sites More sharing options...
Yorkshire Dale Posted April 30, 2008 Report Share Posted April 30, 2008 U will never look back if u but the trial one? Its amazin!! Better than chris king for bein reliable too!! Quote Link to comment Share on other sites More sharing options...
