Hope Carbon Brake Levers
Ben H!
Go on tarty and you'll see that theres 07 levers and 06 levers and they are both different shapes. :S
Yes, but why should that mean that they are not interchangable? The mounting holes are in the same position, they will fit on either body.
Orite fair enough i didn't think that would work but i'm probably wrong. :$
My mate once has one 06 lever and one 07, and was planning to get another 06 lever blade because he preffered the squarer feel, and swapped the blades over to check if the fitted each others bodies, and they did.
