Cleaning My Bike
spartan
Ok so basically i decided that i would bring my bike into work and clean it all off.
I pulled the chain off and the rear cog and everything and cleaned it all with bike lust.
So i put it all back together and adjust my vee pads and jump on the bike and my vee brake had lost ALL power.
Before i cleaned it it was working amazing with great power and bite.
Now it feels like crap, no bite to speak of and i will pull the lever to the bars and the brake will still slip when i rock.
All i did was clean the braking surface with bike lust, some may have gotten onto the pads but i gave them a light sanding also. I have a medium grind with rock blue vees pads and use a hint of tar.
Why the f**k to my brakes suck the big one now clean when the kicked ass dirty??
Im so pissed!
Not sure what this bike lust stuff is, Im guessing its a cleaning agent type thing but what I would do is regrind the rim and sand the pads down. I would assume its the bike lust stuff thats contaminated the brake making it go poop. Regrinding and sand down the pads will remove it from both surfaces.
If it's designed for cleaning paintwork/metalwork, it's pprobably oil based or containes wax. Degrease or regrind the rims and it'll be fine... Sand the surface of the brake blocks too just in case they're at fault (Pretty unlikely to be a problem for long on a ground rim though).
Have you tryed putting on a new layer of tar?
Because if you had to resort to using tar, your brake most proberly wasn't that good to begin with. And if the 'cleaner' f*cked up the tar a little - your brake would now be as you described.
Yeah quick regrind and a couple o mins to bed in and its perfect now.
I dunno but does anyone have trouble with the rock blue pads, i just cant seem to get the bite i want with them, maybe cuz my grind isnt super hard but i find i always need to use tar.
Thanks for the help though,
Ian
