tris Posted April 20, 2008 Report Share Posted April 20, 2008 i do a lot of street riding. and i want to learn tricks such as the fork glide. to do this i need a front stunt peg (only one)i need to find out the easiest way to attach one to my bike. i do not really want to replace my front axle to a bmx size one in order to attach a stunt peg. should i drill through the lower part of the fork leg in order to put a bolt through, and then attach the peg on the other size??i really need some opinions on this so any help would be appreciated. thanks. Quote Link to comment Share on other sites More sharing options...
Callum-Luvs-Trials Posted April 20, 2008 Report Share Posted April 20, 2008 Funbolts?Just put the stunt peg on then screw the funbolt up tight.Might work. Quote Link to comment Share on other sites More sharing options...
tris Posted April 20, 2008 Author Report Share Posted April 20, 2008 i'd be worried that they would be too weak......any other ideas?? i was thinking of using the other small hole at the bottom of the forks that i think is there for stablisers on kids bikes or something?? the hole is small but i may be able to adapt it on some way.... Quote Link to comment Share on other sites More sharing options...
neomember Posted April 20, 2008 Report Share Posted April 20, 2008 I hope that you are using a CR-MO fork. It will not work on aluminium. It will feel weird if the peg is not attach to the axle. You'll be higher than your axle is. Quote Link to comment Share on other sites More sharing options...
Luke Rainbird Posted April 20, 2008 Report Share Posted April 20, 2008 Rear skewer and washers makes for mini peg Quote Link to comment Share on other sites More sharing options...
Revolver Posted April 20, 2008 Report Share Posted April 20, 2008 You can get 10mm pegs. Quote Link to comment Share on other sites More sharing options...
Andrew Smith Posted April 20, 2008 Report Share Posted April 20, 2008 You can get 10mm pegs.or these micro pegs http://www.alansbmx.com/product_info.php?c...roducts_id=2856 Quote Link to comment Share on other sites More sharing options...
