Ashley-Wood Posted April 21, 2008 Report Share Posted April 21, 2008 i like to see the nice cranks come along the same as they do in most pythons through the welds booster stops cracking Quote Link to comment Share on other sites More sharing options...
Muel Posted April 21, 2008 Report Share Posted April 21, 2008 Its what you like i spose I love the fact that your shocked that I prefer disc. It's not uncommon you know, there are a lot of riders that use rear disc brakes, including Benito Ross and many other top level Mod riders.The reason I prefer a rear disc is it feels smoother to ride, less maintenance and less noise. I hate the on/off feel of a maggy, the noise, the constant fiddling with it to try and get it to work, replacing brake pads every couple of months. The list just goes on.I ride these two bikes next to each other regularly, and my Echo is definately the one for me. Quote Link to comment Share on other sites More sharing options...
Adam-Griffin Posted April 21, 2008 Report Share Posted April 21, 2008 How can you even remotely say thats true ? If your bolts are tight then how can they move, if that was the case, Magura's would be supplied with 4 bolt boosters.Last time i bought one, they were.... Quote Link to comment Share on other sites More sharing options...
Ashley-Wood Posted April 21, 2008 Report Share Posted April 21, 2008 I love the fact that your shocked that I prefer disc. It's not uncommon you know, there are a lot of riders that use rear disc brakes, including Benito Ross and many other top level Mod riders.The reason I prefer a rear disc is it feels smoother to ride, less maintenance and less noise. I hate the on/off feel of a maggy, the noise, the constant fiddling with it to try and get it to work, replacing brake pads every couple of months. The list just goes on.I ride these two bikes next to each other regularly, and my Echo is definately the one for me.I would love to run disk, its jsut that my mod typhoon doesnt have disk mounts, if it did i would have my avid juicy straight off my jump bike and onto my trials bike Also pads last alot longer and you dont have to mess around with it alot so i would say disk ***. Quote Link to comment Share on other sites More sharing options...
eskimo Posted April 21, 2008 Report Share Posted April 21, 2008 I've said it before a few times. Removing a booster (depending on the pads, frame and booster) can increae noise AND performance. It'll bite quicker and hold a bit better. Though this obviously depends on the setup, if you've got a crap brake and your running a booster, try it without. You'd be suprised.He's more than right. Also wear rate is increased when a booster is used. Quote Link to comment Share on other sites More sharing options...
Muel Posted April 21, 2008 Report Share Posted April 21, 2008 I would love to run disk, its jsut that my mod typhoon doesnt have disk mounts, if it did i would have my avid juicy straight off my jump bike and onto my trials bike Also pads last alot longer and you dont have to mess around with it alot so i would say disk ***.Make an adapter for it, it's what I did, everyone said it wouldn't work and it was a bodge, I had it on for 6 months and only took it off to get the back wheel out. Quote Link to comment Share on other sites More sharing options...
Ashley-Wood Posted April 21, 2008 Report Share Posted April 21, 2008 Make an adapter for it, it's what I did, everyone said it wouldn't work and it was a bodge, I had it on for 6 months and only took it off to get the back wheel out.May give it a go, you got anypics? Quote Link to comment Share on other sites More sharing options...
Muel Posted April 21, 2008 Report Share Posted April 21, 2008 (edited) Yes several, but I also made a wiki of how to make it, but the wiki isn't working at the moment. Edited April 21, 2008 by Muel Quote Link to comment Share on other sites More sharing options...
Alex.loves.boys Posted April 21, 2008 Report Share Posted April 21, 2008 thing isyou people are right and wrongon my t-pro without a booster my brake had loads of noise and bite but no hold put a booster on, a little less bite but holdon my pure brake was cack without a booster, felt cack, had noise, put a 2 bolt magura booster on made it quiet but becuase my frame wasnt bending outwards the brake now holds really well.if you dont NEED a boosterthen dontbut if you havnt got a inbuilt booster most of the time its best to have one imo.saying that my echo lite which is suposed to be very flexy at the brake mounts i ran no booster and it was mintall depends on pad's and set up i suposse. Quote Link to comment Share on other sites More sharing options...
G-baby158 Posted April 21, 2008 Report Share Posted April 21, 2008 Riiiight. That doesn't actually make any sence. Increased noise - yes, thats a well known fact about boosters reducing noise. Better brake? Find that hard to believe, more likely it wasn't set up properly/well.Yes i find that hard to believe aswell, it might make a louder noise but its not going to make it work better, brake boosters are made to help the brake not prevent it from its full ? pretenchal ? and if it has made it better then yeah it prob wasn't set up properly. Quote Link to comment Share on other sites More sharing options...
Krisboats Posted April 21, 2008 Report Share Posted April 21, 2008 you people are right and wrongall depends on pad's and set up i suposse.Thats exactly what i said and always have said On an already stiff frame, the addition of a booster usually hinders the brake rather than aiding it. And they can help on a frame with a lot of flex.Seems brakes are good if the components (pads, clamps, frame) can all flex slightly, but poor once all the flex is put on one component (the pads), at a guess i'd say it compresses the pads more and moves them out of their optimal performance boundaries. Quote Link to comment Share on other sites More sharing options...
forteh Posted April 21, 2008 Report Share Posted April 21, 2008 On an already stiff frame, the addition of a booster usually hinders the brake rather than aiding it. And they can help on a frame with a lot of flex.Heatsink cnc reds on an echo hifi with an echo control booster works worse than without, more flex but way more bite and hold Quote Link to comment Share on other sites More sharing options...
