2k8-looney Posted April 15, 2008 Report Share Posted April 15, 2008 Hello there My crank arms keep coming loose no matter how tight i do them up, I have tried putting loctite on them but they still come loose so when im out riding i am constantly tightening them witch gets really annoying.What do think could be wrong ?cheers Steve Quote Link to comment Share on other sites More sharing options...
Gogz- Posted April 15, 2008 Report Share Posted April 15, 2008 if it keeps coming loose and you have tightened it right up its ether going to be a worn crank arm or BB . i had the same problem both the square taper on the crank and the axle of the bottom bracket were worn , as far as i know the only way to sort this is to replace them Quote Link to comment Share on other sites More sharing options...
forteh Posted April 15, 2008 Report Share Posted April 15, 2008 If its square taper then youre about stuffed as youve probably stretched the square by overtightening it, if its isis then its just the crap design of the isis spline Loctite wont glue a rocking spline together, it will stop a tight spline or a bolt from coming loose though That is assuming you used the loctite properly. Quote Link to comment Share on other sites More sharing options...
tom aky Posted April 15, 2008 Report Share Posted April 15, 2008 Hi i had the same problem when the thread on the crank bolt and BB messed up the crank just falls off after riding for about 5seconds so im replacing the BB id suggest you do it aswell. Hope this helps. Quote Link to comment Share on other sites More sharing options...
onzamann07 Posted April 15, 2008 Report Share Posted April 15, 2008 i had this with my old onza cranks? i put a bit of metal strip inbetween the crank and bb and it held for about 2-3 month! i got it from them steel bands that hold crates of bricks together hope this helps ? Quote Link to comment Share on other sites More sharing options...
