Bottom Bracket Makes A Grinding Noise
Take of your cranks and bb, clean them, lube and refit making sure the crank bolts are tourqued at 310 in-lbs (35 Nm). do the same with the pedals and BB.
If you are still getting the grinding/cracking noise you know its new bb time!
Sounds like a cracked ball, if its a creaking noise its more likely to be loose cranks or BB but in my experience a cracking noise is dead balls. Take the BB out and turn it by hand whilst holding the shell, you should be able to feel a notch or roughness when it makes the noise :)
it'll feel gritty or tight...as if you can feel a bit of resistance in one spot
