matt middler Posted April 14, 2008 Report Share Posted April 14, 2008 At the moment I have an 18t on the rear and 22t on the front, but out riding on Sunday I just couldnt get enough power through the pedal kicks. If I were to get a 17t would I notice much difference or shoud I just go for a 16t? Quote Link to comment Share on other sites More sharing options...
froob Posted April 14, 2008 Report Share Posted April 14, 2008 17 and 16 tooth sprockets will make it harder to get power down.I'd go for 22 on front and 19 on back personally Quote Link to comment Share on other sites More sharing options...
Peperami Posted April 14, 2008 Report Share Posted April 14, 2008 Erm, why do you need that much power?! Most pros run 18/16 or 18/15... im running 16/14 and it feels fine.On a 22 i was running a 19t, and found that a bit hard, especially for natural... Quote Link to comment Share on other sites More sharing options...
matt middler Posted April 14, 2008 Author Report Share Posted April 14, 2008 I don't mean I couldn't get enough power because it was to hard to pedal, it was too light. so I want something to make it a bit harder. Quote Link to comment Share on other sites More sharing options...
Karl Butcher Posted April 14, 2008 Report Share Posted April 14, 2008 If you go down one on the rear it might help! i run 18-14 it feels really nice! Quote Link to comment Share on other sites More sharing options...
monkeyseemonkeydo Posted April 14, 2008 Report Share Posted April 14, 2008 Try it and see? Whatever you end up with you'll get used to it. I'm currently running 18/13 on my Inspired and it felt super stiff to start with but within a couple of hours I got used to it and can still back wheel, gap and sidehop just as well as before. Quote Link to comment Share on other sites More sharing options...
Greetings Posted April 14, 2008 Report Share Posted April 14, 2008 22:18 is very heavy.If you want to learn to gap properly, you should use a lighter ratio. Gap with your body, not just by pressing the pedal. Quote Link to comment Share on other sites More sharing options...
sstein Posted April 14, 2008 Report Share Posted April 14, 2008 It all depends on wheel size, a gear ratio on a 26'' will feel much easier on a 20''. Also it is important to use what you feel comfertable with, don't let anyone tell you that your gearing is totally wrong if it is right for you. I use 22:17 and it works for me, though might change to 22:19. If you are really noticing that you need more power though go for the 2 tooth difference as with one tooth you won't notice any real change. Quote Link to comment Share on other sites More sharing options...
Matthew_Gibson Posted April 14, 2008 Report Share Posted April 14, 2008 22:18 is very heavy.If you want to learn to gap properly, you should use a lighter ratio. Gap with your body, not just by pressing the pedal.I found 22:18 was a nice ratio. But that was just for me. Some people prefer 22:17 which is even harder, Now running 18:15 which is the same as 22:18. Its all really down to personal prefference. Quote Link to comment Share on other sites More sharing options...
