Echo External Bb
Danny Kearns
You only need to take one cup off to fit the BB. If there's no flange on one side of the bb, thread the BB in to the frame at that side with the rest of the BB hanging out of the frame and you'll have a bit more leverage to pull the cup off. Stick up a photo in case people have specific issues with that type - if what you're describing as an external bearing BB is of the same style as Hollowtech II/X-Type/Whatever Truvative call theirs, this solution won't work, but this system usually only has a plastic tube joining the bearings on each side of the frame.
