Bent Echo Urban And Pure Forks
lapsa
Bent echo urban and pure fork. Urban lasted me about 2 months and pure bent in just a few weeks (they both bent from hooking and were new). Can you suggest me some stronger forks?
Here is me riding with bent urban fork: http://www.dailymotion.com/video/x4r2y7_5diena_extreme
And me hooking: http://www.dailymotion.com/related/7981999...hook-up_extreme
Wheelbase in both pictures is ~1135
I say you do some taps and bend them back :lol: then they will be good as new.
hmmm try the Viz forks, there quite strong!
Im using them now and they are good , by that i mean strong and stiff.
http://www.tartybikes.co.uk/product.php?id=10212
http://www.trials-uk.co.uk/product.aspx?productid=393
The steerer is very strong and the disc mounts come very well aligned so you dont need them facing which is a nice supprise for deng. My echo urbans were so out (the facing tool would not even fit), i had to send them back.
Hope it helps
oh my god, pure fork too :D
you're monster!
Pure forks are shit.
so are control forks and urbans.
the 07/08 range dont have U6 alloy legs, so just bend/snap easy. i put about 4 cracks in my urbans in 3 months and i dont hook or tap.
bent forward forks must make tapping so easy (Y)
The ZOO! fork is very strong, because of the machined crown that goes very low and provides a huge surface for welding the legs. I have one and i think it s the best aluminum fork available.
but if you tend to bend forks easily (which seems to be the case), i believe steel is better. curtis makes one with a reinforced steer tube as an option.
good luck and try to absorb when you hit the front :rolleyes:
Fakin' ell.
Forget different forks, get some slim fast. How can Damon Watson do inhuman hooks and front wheel gaps and not bend his forks...
I bet he does though. How would you know anyway? Just because you saw him in his vids? Well what if the forks in the majority of the clips where new every time..
