Lazy Piston In My Magura
sideburns(dnt ask)
Wheel out, pads off, put something across the front of the 'good' piston to stop it moving, then squeeze the brake lever. Spray some lube onto the piston that's being slow, then pump the lever a few times. Wipe off any crap that comes off on the piston, and repeat a couple of times. That usually sorts it.
Alternatively, you might just be using a load of TPA adjustment, which tends to have almost the same effect. Cleaning the pistons is always a sound idea though (Y)
