maxwellduryea Posted April 4, 2008 Report Share Posted April 4, 2008 Does anyone know what exactly Hope changed between the regular Mono Mini and the trials mono?Is it just the pad/disc/braided hoses or is there more?I emailed Hope, and havent heard back from them in two weeks:( Quote Link to comment Share on other sites More sharing options...
Matthew62 Posted April 4, 2008 Report Share Posted April 4, 2008 Larger piston, creates an increase in power that is more suited to the nature of trials riding......so there we have it, big ass piston. Quote Link to comment Share on other sites More sharing options...
Muel Posted April 4, 2008 Report Share Posted April 4, 2008 The mechanical advantage is greater, giving a more grabby/holdy/powerful brake. Quote Link to comment Share on other sites More sharing options...
forteh Posted April 4, 2008 Report Share Posted April 4, 2008 ^^^ What they said, the larger piston gives a slightly spongier brake but with more bite and hold Quote Link to comment Share on other sites More sharing options...
maxwellduryea Posted April 4, 2008 Author Report Share Posted April 4, 2008 but they didnt change the caliper, the pads, the disc, or the lever? Quote Link to comment Share on other sites More sharing options...
forteh Posted April 4, 2008 Report Share Posted April 4, 2008 but they didnt change the caliper, the pads, the disc, or the lever?Levers the same but the caliper has larger pistons, its only a matter of a couple of mm but its enough to make the difference Quote Link to comment Share on other sites More sharing options...
Matthew62 Posted April 4, 2008 Report Share Posted April 4, 2008 Well obviouslly the caliper is different as it houses a bigger set of pistons, therefore needing different brake pads. SO they've all changed. Lever doesn't need changing as we don't really need a trials specific level (same as the Magura level will do). The discs are always changing with hope brakes, i'm sure i remember something where they updated it (not sure if that was just for the mono trial) - but you can use a variety of discs on the brake to tialor it to your needs.Work and development with trials riders went on aswell to ensure the brake was up to the job....so yeah stuff has changed and afteral they produced a trials specific brake, they didnt just re-name the mono mini. Quote Link to comment Share on other sites More sharing options...
