Care To Explain?
Ben John-Hynes
I think its that thing someone posted a few weeks ago where you have 2 gears but no shifter. Basically you pedal one way to set off in a slick gear then when you get going you pedal the other way for a harder gear.
OBM knows about this stuff, I'm pretty sure it's retro drive, it uses two freewheels, so when you pedal foward on freewheel engages, giving one gearing, and when you pedal backwards the other freewheel engages, giving you the other gearing.
