Ollie Histon Posted April 2, 2008 Report Share Posted April 2, 2008 i seem to remember ageeessss ago there was another topic with the same problem as me, (which i couldn't find on the search sorry). anyway i think i remember a lot of people having problems with their chain slipping/skipping when they had just put a new surly cog on the back.i have this problem, does it just need to to wear in a bit? or is it maybe not the cog at all and ive got it wrong?thanks for any help anyway. Quote Link to comment Share on other sites More sharing options...
psycholist Posted April 2, 2008 Report Share Posted April 2, 2008 What's your chain tension like? If the chain is reasonably tight it can't slip. If you're getting clunking from the chain as you pedal, the chainline might be off, causing the teeth of the sprockets to catch on the side plates of the chain. Quote Link to comment Share on other sites More sharing options...
Ollie Histon Posted April 2, 2008 Author Report Share Posted April 2, 2008 my chainline is practically dead on, but the tension isnt as tight as it could be. im running a KHE chain with a mech which only has one jocky wheel. you think that could be it? Quote Link to comment Share on other sites More sharing options...
psycholist Posted April 2, 2008 Report Share Posted April 2, 2008 If the chain isn't wrapped around enough of the back sprocket it can sometimes lift right off the teeth under load. See if you can take another link out of the chain to shorten it up, so the derailleur is pushed right up towards the chainstay and the chain wraps around as much of the back sprocket as possible. Quote Link to comment Share on other sites More sharing options...
alex_jsy Posted April 2, 2008 Report Share Posted April 2, 2008 had problems with my khe chain too... seems that my tensioner wasn't keeping the chain tight enoughdue to there being so many stiff links, best thing to try is maybe taking a link out if you can, if not lube up the chainas much as you can to make it less stiffif that fails try another chain, switched to my half link chain and had no problems...until it snapped Quote Link to comment Share on other sites More sharing options...
