Sam-Addy A3 Posted March 31, 2008 Report Share Posted March 31, 2008 Hi, I know someone eelse has probably posted the exact same topic as this but i couldn't find it.When you submerge bleed a Magura, does it just take the air out and leave the fluid in or does it water bleed the brake aswell?ThanksSam Quote Link to comment Share on other sites More sharing options...
Headley Posted March 31, 2008 Report Share Posted March 31, 2008 (edited) If you do it right then u'll be left with a brake full of liquid and no air. It's a way of garanteing(sp) you have no air in the system. Edited March 31, 2008 by Headley Quote Link to comment Share on other sites More sharing options...
Revolver Posted March 31, 2008 Report Share Posted March 31, 2008 Hi, I know someone eelse has probably posted the exact same topic as this but i couldn't find it.When you submerge bleed a Magura, does it just take the air out and leave the fluid in or does it water bleed the brake aswell?ThanksSam if you do it for long enough, it will replace the oil with water.if you don't do it for long enough, you'll have oil and water, which don't mix Quote Link to comment Share on other sites More sharing options...
